Steering wheel shimmy going over bumps.
#31
Yeah, it's been a huge PITA...it's funny how the very last thing it should have been, was actually the problem. They were actually joking about it in the shop "If those were like some other aftermarket thing or Koni's, I would have been like 'see, that's what you get buying cheap stuff.' but I never would have guessed Bilsteins." lol. Not sure I would have lumped Koni in there, but I assume since they're a race shop, they probably see quite a bit come through...hopefully I get the car back today and back on the road ready for Amelia/Werx Reunion in 2 weeks.
The following 2 users liked this post by Nate.Evans:
GC996 (02-16-2023),
TheChunkNorris (02-16-2023)
#32
#33
Yeah, it's been a huge PITA...it's funny how the very last thing it should have been, was actually the problem. They were actually joking about it in the shop "If those were like some other aftermarket thing or Koni's, I would have been like 'see, that's what you get buying cheap stuff.' but I never would have guessed Bilsteins." lol. Not sure I would have lumped Koni in there.
At some point Bilstein switched from a threaded steel gland nut on the top to a plastic press fit cap. I'm curious if yours has the same type cap and if that cost cutting measure is part of the reason for the leaks.
BTW, mine went out back in 2016 and it still feels like it has a full charge of gas 7 years later (I have no idea why I saved it this long ).
#34
guys thanks for support, im definitely going to have rims looked at once again, maybe put car on lift and inspected, maybe even try a set a wheels (once I find a volunteer), if no luck, ill have another professional look at it, I cant see why im not able to run spacers.
Also was debating with a friend of my about it, told me had same issue with his car and H&R spacers in past. Guys think its possible bad spacers is a thing? I find it hard to believe, since ive always ran h&R spacers in previous cars and never had an issue. IM almost certain the issue is there and spacers augment it .
Guess i could also try using oem bolts for wheels not the H&R ones just to see if its a bolt problem. since another member had that issue.
thanks for tips and support,
any members here from Long Island NY.
