996 Forum 1999-2005
Porsche 996 ECU replacement
Old Feb 7, 2023 | 11:36 AM
Vishwaka's Avatar
Vishwaka
Default Porsche 996 ECU replacement
Hi all,
Could use your input on a matter.
My 1999 996 was missing, and the idle was hunting. When the agents looked at it, they found that the ECU voltage is low, and couldn't be fixed. I now have to change my ECU.
Does anyone know where I could buy a 996 ECU? Also, would a pre-owned ECU be ok to plug in, or would it have to be reconfigured?
Thanks in advance!
Vishwaka
Old Feb 8, 2023 | 01:47 PM
JFP in PA's Avatar
JFP in PA
Swapping DME's without recoding will simply not work.
Old Feb 8, 2023 | 02:36 PM
allcool's Avatar
allcool
Originally Posted by Vishwaka
Hi all,
Thanks in advance!
Vishwaka
I'd get a trusted professional second opinion diagnostic for sure and try and avoid changing out the original. Its a specialized coding job to get it right. As ecu(DME) & immobilizer unit under the driver seat, & all keys,,, all need to be coded to match each other perfectly or no start/no run.
There was just a good thread on the same subject, you should read it....
If ecu is positively needed, ECUDoctors is the place to go, they can fix your original more than likely, and if needed can code the complete set. They're good guys.
jmo
Old Feb 8, 2023 | 02:41 PM
Porschetech3's Avatar
Porschetech3
Are you talking about the 5 volt reference volage the DME sends out to Sensors is much lower than 5v ? If so, that is very unusual and like Jeff and others have said, any other DME has to be programmed using PIWIS with IPAS codes that only authorized persons have accesss to..
Old Feb 8, 2023 | 04:05 PM
dgmark's Avatar
dgmark
Good used ecus can be had for a couple of hundred, Ecu doctors can code the immobilizer If you send them the keys and security module. They can also bypass the security altogether if you want.
Old Feb 10, 2023 | 05:46 PM
pretarch's Avatar
pretarch
Thanks @dgmark and @allcool
@Vishwaka Getting used ECUs for a 996 is not like in the older cars where you could get used unit and test things out.
Programming is necessary.
See these 2 videos that explain it in detail:
and
