Vision Vents??
Vision Vents??
I have been dealing with the black foam in my car for a while, and deal regularly with the windshield fogging up. Most of the time the defroster clears it up, but not always. I got one of the email promotions for the vision vents to fix the issue, but I wanted to know if other people have installed them and if they really worked. thanks!
Vision vents does not "fix" the issue, it is just a bandaid.
A VERY expensive bandaid.
For less than $50 you can actually fix the issue.(blend doors)
Yes, the fix does take longer than covering the defrost vents.
There are several threads here on how to DIY fix the blend doors.
It took me about an hour to fix the one that is access via the frunk, and about 45 minutes to fix the one behind the radio.
binaryaudax (08-30-2023)
IF I didn't want to do the repair myself, I'd rather put the $350 towards three hours of labor at my local Independent for them to do it.
The following 2 users liked this post by Idaho911:
JohnCA58 (01-16-2023),
TexSquirrel (01-16-2023)
Vision Vents Work for Me
