996 Forum 1999-2005
Do These Cylinder Walls Look Normal?
Old Nov 16, 2023 | 08:10 AM
  #136
Jagtem's Avatar
Jagtem
Originally Posted by Drumheros
Hi Jag, I'm following this thread with a close interest. Have you had any more interactions with the engine builder? I am interested to know who it is at this point - I think that would be fair enough given the runaround you've been given. Hope you've had some luck with the lawyer.
The engine builder was MB Motorsports.
Final update: I'm pretty much screwed. I've decided against fighting them in court. I'm taking this as an expensive lesson. I'm now living in Europe and the car was sold as a project to a kid in California.
I posted a much more in-depth account in the form of a warning to others here: https://rennlist.com/forums/996-foru...l#post19111764
Old Nov 16, 2023 | 10:20 AM
  #137
Charles Navarro's Avatar
Charles Navarro
Platinum Sponsor
Sorry this didn't work out in your favor.
FWIW, MB Motorsports was banned from Rennlist quite a few years ago.
Old Dec 23, 2023 | 09:37 AM
  #138
silver_tt's Avatar
silver_tt
Originally Posted by yelcab
Here are the two
Originally Posted by Charles Navarro
Yes, just a squiggly line.
Happy holidays Charles and yelcab! I have a question for you both, please correct me if my thought process is not right.
Looking at yelcab's photo above for reference, humor me for a second in a hypothetical scenario where a bore has no scoring but does have a structural crack at the top of the cylinder that is serious enough to develop into D-chunk over time. Scoping from the sump even with the piston at TDC would have missed this, no?
Old Dec 23, 2023 | 12:14 PM
  #139
yelcab's Avatar
yelcab
If you had a crack like that in the cylinder, the car is un-drivable because it would misfire, spew out white smoke via the back smelling of coolant, cappuccino color engine oil, and you would have to stop driving it way before it has a chance to D-chunk the engine. That engine actually had TWO cracked cylinders and the case was sent to Charles of LNE to do a 3.8L nikky job. My neighbor is driving it now and he is quite happy with it.
And you would not see it if scoping from the bottom of the engine, but it is a moot point because the oil intermix would give it away without the need to stick a scope up its ash.
Old Dec 23, 2023 | 12:22 PM
  #140
silver_tt's Avatar
silver_tt
Thank you for the reply and for the information you have posted here. I completely agree with everything you said but my initial thought was hypothetically if there were signs of stress before the cracking got anywhere near a chance to actually D-chunk off, and thus before the milky oil/coolant, it seems strictly theoretically that this could be missed in a sump borescope inspection. There is no question the sump is the best singular method to borescope but for engines that can D-chunk (and I thought I saw Charles post a few months ago that he's seeing more of these now) I was wondering if they would actually advise then scoping from the spark plug to check for any structural anomalies at the top of the bore. Seems like you might need to do both, depending on the specific engine, to be the most safe in a PPI.
If I ever have this issue I would send to Charles as well so good call on that. Thank you for the information and insight.
Old Dec 23, 2023 | 12:27 PM
  #141
GC996's Avatar
GC996
Doubt we will ever truly know, but it would be interesting to know how many of these cracks/d-chunks came from failed water pump blade or from a failed AOS.
Old Dec 26, 2023 | 05:17 PM
  #142
Charles Navarro
Platinum Sponsor
Yes, scoping from the sump would have missed it, but the engine would have had intermix with a crack like that in the bore, even without it becoming a full fledged d-chunk failure.
Old Dec 26, 2023 | 05:18 PM
  #143
silver_tt's Avatar
silver_tt
Yes, that makes sense, I was thinking about it more over the weekend and thought the same after giving it more thought and reading yelcab's notes. Thank you Charles and yelcab for the information, very much appreciated.
Old Dec 26, 2023 | 05:20 PM
  #144
Charles Navarro
Platinum Sponsor
Based off what we've seen, it's mostly 3.4 996 engines that crack or have d-chunk failures, so basically the Lokasil I blocks. We do from time to time see a 3.6 with a cracked bore, but it's far and few between with Lokasil II and III blocks.
That said, it might not be a bad idea to also scope from the spark plug if looking at a 996.
Old Jan 1, 2024 | 09:23 AM
  #145
silver_tt's Avatar
silver_tt
https://lnengineering.com/products/w...e-scoring.html
"Porsche models with Alusil blocks including Panamera, Cayenne, Macan, as well as Boxster, Cayman, and 911s with the 9A1/MA1 engine should also be bore scoped to check for bore scoring, however with these engines inspection through the spark plug hole with the piston at BDC is the only option." (underlined emphasis my own)
So much valuable information on your website and so many topics covered it is insane. On the 9A1 obviously scoring is much less of a concern but is still a concern. Why exactly is inspection through the spark plug hole the only option on the 9A1? Obviously the passage must be blocked but do you know specifically how? Since you cannot access through the sump does this mean the bore scope on 9A1 is less conclusive?
Sorry for always asking you so many questions but this is what you get for knowing so much and being smart
Old Jan 3, 2024 | 10:10 AM
  #146
Charles Navarro
Platinum Sponsor
The way I describe it, the MA1/9A1 engine has a lasagna bolted onto the bottom. Too much stuff in the way unfortunately. I still think there is value in scoping, but you have to make sure it's with a high res camera to catch even the slightest signs of scoring. Used oil analysis for sure would catch it first.
Old Jan 3, 2024 | 10:16 AM
  #147
silver_tt's Avatar
silver_tt
Thank you, love the visual image I am getting from the description haha Last question and I promise I am going to stop bothering you for a while: Do you know the model of the bore scope you are using?
I know I have told you before but I really appreciate the information you have given me. You have greatly improved the value of RL with the information you have posted.
Also the more I think about it UOA is almost more important than the bore scope in the sense that it is easier to read the results and not make a mistake. I am concerned than many people, even professionals, are not doing the bore scope procedure correctly and do not know how to read the images.
Old Jan 3, 2024 | 10:53 AM
  #148
Charles Navarro
Platinum Sponsor
I know lots of shops use the Snap-On scope.
This is the one I have:
Amazon Amazon
Old Jan 3, 2024 | 11:05 AM
  #149
silver_tt's Avatar
silver_tt
THANK YOU. Was going to guess Snap-On but the one you have has more and better features for the price. Fully waterproof, 360 degree 4-way articulation, all the different light settings, that thing is a steal for $400 (actually looks like even less when I login with Prime). Thanks again.
Old Jan 3, 2024 | 03:57 PM
  #150
wdb's Avatar
wdb
https://www.amazon.com/gp/product/B0B2LK2R5H
That is a COOL scope! I wanted articulation too, but cheaped out a little:
Amazon Amazon
