996 Forum 1999-2005
installing rear sway bar drop links. What am I missing?
Old 01-12-2023 | 03:09 AM
Otto Bonn's Avatar
Otto Bonn
Default installing rear sway bar drop links. What am I missing?
Had these sent out from FCP Euro. Figured I would install them while doing my transmission mount.
Looks straightforward, but how do you rotate the end of the link that threads to the welded nut in the cup at the bottom of the shock Dampener. There are flats only on two sides so you need to rotate it 180° before you can reposition your wrench which is not going to happen with all the suspension links and control arms in the region. It needs to be six sided. Even a stubby won't rotate 180°.
Obviously I am embarrassed. Don't know how it should be done.
Old 01-12-2023 | 09:35 AM
hardtailer's Avatar
hardtailer
You turn the nut (as you should always do in a bolt and nut combo). The flats are there to prevent the stud from turning. Position them such that the wrench can easily reach them and turn the nut to tighten.
Old 01-12-2023 | 09:42 AM
Coopduc's Avatar
Coopduc
You can’t install them because you can’t rotate the stud enough to allow the wrench to reposition. The nut is not used. I purchased the same parts from FPC and returned them for another brand (TRW if I recall). They had a proper hex on the stud that allows you to reposition the wrench properly.
Old 01-12-2023 | 10:28 AM
wdb's Avatar
wdb
Can you attach that end first, by itself, and rotate the entire end link in order to tighten it? I did my suspension last year, don't recall a problem similar to yours, so there must be a relatively simple solution.
Old 01-12-2023 | 11:13 AM
993GT's Avatar
993GT
you have to buy a brand that has a hex on the balljoint side, that style doesn't work
Old 01-12-2023 | 11:20 AM
De Jeeper's Avatar
De Jeeper
U can pull the shock out and install it. I know how much u like to explore your 996 . Here is the trw part.
https://www.fcpeuro.com/Porsche-part...b=9&d=15675&v=
Old 01-12-2023 | 03:52 PM
jdbornem's Avatar
jdbornem
Just to pile on, the stock shock mount is just a hole, so it feeds through, and you turn the nut.
Aftermarket shocks for some reason decided they should have a threaded hole, so you need a different drop link which has a hex head on the ball joint.
Edit:. I might be an idiot. It's been a while since I swapped mine, and I answered before double checking everything. So don't listen to me.
Old 01-12-2023 | 04:34 PM
chris8382's Avatar
chris8382
Default Correct
I found this to be true. Some brands list inaccurate compatibility, despite the part appearing to match. I went through three sets of these links before I got one that would actually work. Not only do you have the problem you described (2 sides vs hex nut), but one set had the wrong threads to fit into my strut.
Now if only I could remember which brand was the perfect fit…..I think it was Meyle, but I could be wrong. Regardless, my lesson here was to not skimp on this part since saving $10 is not worth the aggravation of returning parts.
Old 01-12-2023 | 05:39 PM
hbdunn's Avatar
hbdunn
I am almost 100% sure this is incorrect. My C2 original shocks have a welded nut. I don't see how you could tighten a nut that was not attached.
Old 01-12-2023 | 06:15 PM
jdbornem's Avatar
jdbornem
I edited my post.
​​​​​​​Is it okay to admit when I might be wrong on the internet, or are we supposed to fight to the death no matter what?
The following 3 users liked this post by jdbornem:
dporto (01-13-2023), Dr_Strangelove (01-13-2023), TexSquirrel (01-13-2023)
Old 01-12-2023 | 07:17 PM
De Jeeper's Avatar
De Jeeper
The following 3 users liked this post by De Jeeper:
Porschetech3 (01-13-2023), TexSquirrel (01-13-2023), wdb (01-13-2023)
Old 01-13-2023 | 03:49 AM
Otto Bonn's Avatar
Otto Bonn
Okay, you guys are awesome, group hug or whatever you're comfortable with. I'm flexible.
So here's the deal, yes, it's the rear shock and the sway bar Link at the bottom of the shock. Stock shocks. ( New Bilsteins in a box in the garage for now, that's another story, but in the meantime.. don't shoot me.)
Should be simple but in fact they are stock dampers and the nut is welded in place so you really need a six-sided type. Someone mentioned meyle brand which I have had luck with with other parts in the past and is what these are as you can see on the Dust cover. However, I believe the jeeper is correct. To my eye installing these would require you remove the shock, install the link, then reinstall the two together. alternatively you could remove some or all of the struts and control arm bits just to mount this silly little link.
I think it would be similar to splitting your case, removing your pistons, then cylinder heads, and installing your spark plugs from the inside, then reassembling.
So I'm thinking I might send these back until I develop a little more courage.
Old 01-13-2023 | 03:59 AM
993GT's Avatar
993GT
you have to get the right parts, you can't take the shocks off and get sufficient torque on the stud to avoid shear failure, it's a part flaw copied amongst a number of manufacturers
Old 01-13-2023 | 09:41 AM
EVOMMM's Avatar
EVOMMM
Pay someone else to install them and then blame them
Old 01-13-2023 | 01:17 PM
TexSquirrel's Avatar
TexSquirrel
I ran into the same problem when installing Feal coilovers in the C4.
I ended up throwing them away and reinstalling the original drop links until the owner could buy a different brand.
I had had them in stock for over a year before I had someone need them and then they were impossible to install, even with the shock body outside of the car they did not point in the correct direction.
I didn't have a thin enough nut to make them fit either.
Quick Reply: installing rear sway bar drop links. What am I missing?
