996 Forum 1999-2005
DIY fix for the pad under drivers floor mat?
Old 12-19-2022 | 03:24 AM
Ben8jam's Avatar
Ben8jam
Default DIY fix for the pad under drivers floor mat?
I can't figure out what this thing is called and so can't seem to find a DIY solution to fixing it. Is there anything I can do t get this to reattach to the carpet or should I just cut off the rolled up part and be done with it?
Old 12-19-2022 | 09:19 AM
DBJoe996's Avatar
DBJoe996
Get these https://www.suncoastparts.com/product/SKU9X6RUBBER.html
TexSquirrel (12-19-2022)
Old 12-19-2022 | 10:42 AM
hatchetf15's Avatar
hatchetf15
OP - Unfortunately, this is part of the whole front carpet section, 996 551 011 02 EEW, with no a la carte solution. Take a blade and remove the entirely useless heel pads. One way you can repair this area is cut and glue black Kevlar cloth to both sides for a cost of about $20.
Old 12-19-2022 | 01:52 PM
Ben8jam's Avatar
Ben8jam
Originally Posted by DBJoe996
Already got a set of carpet mats ready to go.
Thanks - that's what I figured - will look at Kevlar patch option too.
Quick Reply: DIY fix for the pad under drivers floor mat?
