Identifying Rattle Noise on Idle
I'm trying to identify the issue causing this rattling noise. It only happens on Idle and immediately goes away at RPMs > 1800. It doesn't sound like the typical bore scoring noise.
and sounds like its near the alternator/belt area. Any ideas here? I posted a video on youtube:
Thanks in advance
Thanks in advance
That engine is really running rough. Pull the air filter box, remove serpentine belt and hand test all the pulleys and water pump, alternator. Check the oil fill pipe for any cracks.
Will do. I changed the airbox recently from K&N intake to a 997 airbox so I thought maybe I messed something up but I don't think thats the issue.
Yes, nice catch! If it is a broken alternator bracket, the movement could have compromised the bearing too.
Make sure you replace it with the beefier 997 bracket shown in Sleepy's pic (part #997.101.021.00). Before you check the price on the bracket, you should be sitting down with a stiff drink in your hand though...
hkovalcik (10-05-2022)
Ha I’m coming back to this thread cause I found the issue and….. the alternator bracket broke and also shredded the belt.
I wish I kept getting emails about replies on this thread so I could’ve found the issue earlier 😂
Luckily I found a replacement bracket and will be installing this weekend
The following 2 users liked this post by colorway:
hardtailer (01-05-2023),
wyovino (01-05-2023)
To those who had this issue, did you lose a lot of coolant when replacing the bracket? Did you have to do a full coolant flush or is topping up enough?
Should I top up with distilled water, red coolant or a mixture?
Thanks again!
Thanks again!
