View Poll Results: Can I drive like this?
Yes no worries!
6
100.00%
No it may be your last drive!
0
0%
Voters: 6. You may not vote on this poll
996 GT3 two piece stripped bolt, safe?
EDIT: I went to the mechanic for a helicoil insert, they were out of M7, they should get them in and problem should be solved. Thanks for all the help!
Hi all,
Just got a set of 996 gt3 rims, one of the small titanium bolts on the outer rim is broken. I did a one over to make sure all is in order but sadly this is the case. How safe/unsafe is it to drive with one of the bolts stripped.
Thansk!
Hi all,
Thansk!
I won’t risk it on a highway but around town np
Vect (08-01-2022)
Is the bolt threads stripped or is the bolt broken?
It shouldnt take much to helicoil the hole.
In the mean time i doubt 1 bad bolt would hurt anything for normal street driving.
dporto (08-01-2022)
^^^ This ^^^… Or, the proper/professional way to do it would be to disassemble the wheel, weld the hole, drill and re-tap for the correct fastener.
Dana Whicker (08-01-2022)
The following 3 users liked this post by hbdunn:
wdb (08-01-2022)
