1999 911 6 peed manual transmission. I
have my differential out would like to know how to remove shaft so I can replace spider gears. Pics, schematic, etc, would help.
I should remove Bearing than ring gear and that will allow spring pin to come out. Will it be hard to reinstall bearing back. Will heating it make it easy to get on.
Thanks old retired engineer.
Spider gears r held in by the cross pin. Pull the cross pin and rotate the side gears and they fall out then the side gears can be removed. Be aware there may be thrust washers under them. U need to "time" spiders when u put them back in so they both align with the cross pin holes in the carrier when rotated back in. They both must be rotated back in at the same time. It takes some patients.
The ring gear only needs to be removed if pin cant be pulled past it. The ring gear is a slight press fit. Most people will say to not pull it in with the bolts but its how i do it. The manual will say to put the carrier in the fridge for an hour or 2 to help.
Guard or OS Giken. The factory unit is kinda good but wears out quikly and generally need rebuilt every 30k.
i have not done a porsche ls yet but i will probably have to reset the backlash on the ring gear if u change the carrier to a ls. Usually not had to do with a few correct tools.
Two years ago I decided to get a Porsche with mechanical problems. I research forums, manuals, etc. I noticed your replys and want to thank you for helping us.
