Wheel spacers make your tires and wheels appear wider by moving the wheel out from the hub, providing both performance and appearance improvements. Whether you want improved handling, increase safety, or simply desire your car to make a statement about your individual style, wheel spacers can help you accomplish your goal.
FVD Brombacher Germany conveniently combines Porsche specific H&R spacers, the correct Porsche bolt shoulders and the correct length H&R bolts to take the guess work out of adding spacers to your car. Our spacers are cost competitive and have been developed to work together without compromise. Don't be fooled by the competition whose costs quickly add up by requiring you to order the spacers, bolts and bolt shoulders separately. Also, H&R Spezialfedern GmbH & Co. KG (H&R Springs) is an OEM supplier to Porsche, so why spend more for Genuine Porsche spacer kits, or risk wheel vibration with a lesser brand?
Features:
Includes Proper Porsche Wheel Bolt Shoulders / Ball Seat
Manufactured in Germany by H&R Spezialfedern GmbH & Co. KG (H&R Springs)
Can be used in front and/or rear
996 Sizes/Thickness: 7 mm (.27 inches), 11 mm (.43 inches), 15 mm (.60 inches), 18 mm (.71 inches), 23 mm (.90 inches)
Bolt Pattern: 5/130
Center Bore: 71.6
Bolt / Stud: Bolt
Thread Type: 14x1.5
Color: Black or Silver
Material: Strength Tested Aluminum Alloy
Coating: Anodized for Corrosion Protection
