996 Forum 1999-2005
996 Tiptronic to manual transmission swap - 2004 996.2 Carrera 4S with A9635
Old 07-21-2022, 01:01 PM
TexSquirrel
TexSquirrel's Avatar
Received 2,411 Likes on 1,279 Posts
Originally Posted by theprf
PIWIS 2 wiring diagrams start at 997 (2005) so no coverage for 996. I don't have a PIWIS 1.
Yeah, I got a copy of the VM with the PIWIS II software.
Disappointed in no coverage of the 996.
Glad I found out before spending big money on a PIWIS II.
Wish I could see what the PIWIS I has.
If it had what the PIWIS II has for the 997 I might consider spending the money if I found one for sale.
For now, I'll stick with the Durametric Professional, Snap-on Ethos Pro & Snap-on Modus Ultra.
Old 08-06-2022, 04:26 AM
modz
3rd Gear
modz's Avatar
e30rapidic thanks so much for this post! I'm about to go through this. Picking up my new C2 996 on Sunday, starting the swap as soon as the gearbox lands from the USA (I'm in southern hemisphere). Cheers
e30rapidic (12-09-2022)
Old 12-09-2022, 08:18 PM
e30rapidic
e30rapidic's Avatar
I'm getting a lot of PM's about this swap from my other post. What could I do to ask for this to go into the DIY section for more visibility? Is it even worthy??
The following 2 users liked this post by e30rapidic:
fasterfaster (03-17-2024), imhighlander (12-11-2022)
Old 02-01-2023, 05:42 PM
kupson
kupson's Avatar
This is one of the most amazing things I have ever read in any forum on any project, car or otherwise.
I would 100% buy you a beer and a steak. Thank you for doing this, and thank you for sharing it. And as others have said, the PDF is pure gold.
e30rapidic (02-02-2023)
Old 02-02-2023, 01:00 PM
e30rapidic
e30rapidic's Avatar
haha, thanks for this. Made my day.
Hope it will be of use to others, I'd love to see some more swaps done!
Old 02-02-2023, 07:09 PM
Tangerine Dream
Tangerine Dream's Avatar
It is 100% worthy! Well done sir!
We are blessed to have your input. Thank you 🙏🏼
e30rapidic (02-03-2023)
Old 02-03-2023, 10:42 AM
e30rapidic
e30rapidic's Avatar
Cheers!!! and thanks.
mackmade (05-27-2023)
Old 05-26-2023, 09:19 PM
mackmade
3rd Gear
mackmade's Avatar
Any chance you could post pictures of the wiring? Or could you send me a dm?
Old 05-27-2023, 09:33 AM
e30rapidic
e30rapidic's Avatar
the pdf attachment with all the wires highlighted is attached to one of the posts. Shows the terminations. Basically it was the clutch switch wire, cruise wire to the cluster and new reverse switch pigtail. 🙂
Old 05-27-2023, 10:07 AM
mackmade
3rd Gear
mackmade's Avatar
Is there anything I need to wire that would be preventing it from starting? Not sure if I’m chasing the right issue
Old 05-28-2023, 10:01 AM
theprf
theprf's Avatar
Received 1,776 Likes on 1,131 Posts
The clutch switch will prevent the starter from cranking the engine. Did you ground that pin on the ECU?
Old 05-28-2023, 01:34 PM
mackmade
3rd Gear
mackmade's Avatar
Running into an issue as my car is a 99. and appears to have a different pin out to the dme
Old 05-28-2023, 03:17 PM
e30rapidic
e30rapidic's Avatar
Putting this here as early cars seem to be different. Will investigate more soon….
Old 07-05-2023, 05:38 PM
neversummer
neversummer's Avatar
Do I need a computer to do any reprogramming? I know the OP said he was using one to try to clear the transmission error but after swapping the cluster that error went away. And if I do need one, can I complete the swap enough to drive the car to a shop that could do the last bit of reprogramming for me?
Old 07-09-2023, 05:39 PM
e30rapidic
e30rapidic's Avatar
I used a PIWIS II, was able to tell the dme the transmissions type but it ran/drive fine as soon as I put the manual cluster in.
It ran/drove safely with the tiptronic error message in the cluster, was just down on horsepower a bit. Limp mode I suppose? So I will say yes, you can drive it to a shop for the last bit of programming.
Quick Reply: 996 Tiptronic to manual transmission swap - 2004 996.2 Carrera 4S with A9635
