Ride too stiff
Ride too stiff
I recently inherited a 996.1 that has the Bilstein PSS10 on it. Pretty stiff, even with the adjusters turned down. I'm not going to track the car, so I don't need anything super fancy. Question I have is, Should I go with the ROWM030 or the KW coilover variant 1? I'm currently using the 996 as a daily and would like a tad bit smoother ride.
Absolutely love this car. Puts a smile on my face everyday on my way to work
These cars generally ride pretty stiff compared to an average car. I find the stock suspension in my C4S a much firmer ride than my WRX. I'm actually getting Bilsteins put on my car right now -- I can let you know how they compare to stock tomorrow.
What tires are you running? Those can also make a noticable difference in street ride quality.
Fracture (04-13-2022)
Lower the tire pressures a couple PSI.
FWIW, three things to think about.
Yep, could be tire pressures. Should be approx 36 F 44 R. But as Prf said, you could lower them a bit. But don't go too low or you run the risk of wearing the outside of your tires quickly and destroying your wheels if you hit a pothole.
The second is that the Hancook's you are running could have stiffer sidewalls than what you are used to. Never used Hancook tires so I can't give you a narrative on feel.
Add in a set of PSS10s which are great coilovers, with low profile stiff sidewall tires, and you have a stiffness that you are not used to.
I do not have any experience with PSS10s, but my car has M030 suspension, but with Koni Actives instead of B8s, which makes it softer over bumps, and it is still a pretty stiff/harsh ride. I don't have a lot to compare it to with other 996s, but I don't think I would recommend this set up if you are looking for something less stiff. If it were me, I would check the spring rates and look at maybe decreasing those a bit, and see if that helps. Otherwise in my experience with other cars, I have no direct experience with coilovers on the 996, you can usually get better ride quality at the performance level from coilovers than traditional spring/strut set ups, especially when lowered.
Also, it's hard to tell from the one pic, but your car looks pretty low, and if that's the case even a ROW M030 will likely raise it.
At the end of the day though it's a sports car and it will never ride like luxury car without absolutely ruining your handling.
You should be able to run 32F 36R with a slight increase in tire wear. I'd drop the pressures in 2psi increments to see if it makes a difference.
Did you ever try running the coilovers with the dampers dialed UP as opposed to down? My Feal coilovers felt harsh and mediocre at halfway point (15 out of 30 clicks), so I turned them down to 10 and then 5 and then 0 trying to improve the ride. It got progressively worse. Then, I tried turning them up to 20 clicks just to see. The ride felt great and got smoother. I eventually set it at 28 front, 26 rear. Haven't touched it in over a year. Feels perfect.
The moral of the story is that an underdamped suspension is bad. It will be harsh and stiff.
If you enjoy the car leave it, spend nothing until your rubber wears more, that won't take long, then premium tires (?Michelin Pilots, Continentals), and keep enjoying it, and tell ride enthuiasts to get a Cadillac.
Can't truly tell with the picture if the car is lowered, but I suspect it is because you are running PSS10s. Which would also lead me to guess that alignment may be set to GT3 specs which is very common and also means camber. With this set-up you will not only have a stiffer ride, but your tires will feel every nook and cranny on the road and follow them giving the steering wheel a very "alive" feel. I love it on my car because I feel everything, but very few folks do, unless they come from a track mind-set. But yes, this would get to be very tiresome as a daily driver. Forget about drinking coffee on the drive to the office.
Keep in the back of your mind that the PSS10s are an excellent set of coilovers, with a lot of adjustability. Don't know what it takes to reverse the lowering and improve the "travel" for a softer ride, but reversing the GT3 spec alignment to neutral is pretty easy.
A good set of all season tires which are typically softer rubber will also help.
As a side note, if in some way you decide to eliminate the "lowering" of the car, a set of spacers will definately help to move the wheels out and fill in the wheel well space.
You also might not know that the PSS10's are adjustable. There are ***** on the top of the rear and the bottom of the front dampers. Higher = softer ride, at last on the PSS9's, which is counter-intuitive.
Absolutely. It took a couple of track days with my indy out at the track but we settled on full stiff in the rear and half stiff in the fronts plus tarret sway bars set the same. Eliminated the understeer that plagues the 996 with factory settings and allowed me to rotate the back end. We will see what adjustments will need to be made when I run with the gt3 front lip. Not as concerned with our local 2 mile track, more concerned with the speeds at Road America with my back end getting squirelly. All part of the fun.
