Clutch pedal creaking noise
Removing this spring may cause issues with cruise control, as that spring helps hold the pedal when not engaged. Without the spring it may trip the sensor indicating pedal movement, which disables cruise control. If you don't use cruise control this obviously isn't much of an issue.
I seem to remember the first 6 months I owned my car, in warm weather only 70-80 degrees, it would make creaking sounds too. It kinda bugged me so I took it to my Indy and he sprayed some sort of lubricant on the spring and it never has made noise since, lol. Don't know if that is the 'fix-all' or not, but my spring is intact and quiet, lol.
Great thread....I have owned brand new, vintage, used manual shift cars. Everyone of those cars had or has clutch squeak. I do what many have suggested and sprayed different lubes on different spots. I'm thinking it is just the nature of manual cars. On a fox mustang, I changed out the whole internal clutch quadrant mechanism, new cable etc. etc. Squeak stopped.....for about a year. Then came back.
This is interesting. I have owned a lot of manual cars mostly 60s and 70s, with a few 80s. Linkage clutches, cable clutches, hydraulic clutches and not one of them has never made any noise that a little silicon spray on the pivot points didn't fix. My 996 has never made any noise before or after removing the spring.
