996 Forum 1999-2005
Dont suffer! - CDR Volume Knob
Old 02-21-2022 | 09:38 PM
Randy Rossi's Avatar
Randy Rossi
Default Dont suffer! - CDR Volume ****
Ok I almost posted this in "what did you do to your 996 today", but its so painfully embarrassing that I thought it deserved its own thread. My 996.2 has the factory BOSE (yes, ugh) CDR-23 and for 2 years of ownership, the volume **** as done that annoying thing where it jumps and or just does nothing. In a youtoob rabbit-hole last night, I saw someone restoring the stickiness issue these ***** have (mine has been garage kept most of its life and doesn't have this issue thankfully). While he had the ***** off to clean/plastidip them, he sprayed inside his head unit with CRC contact cleaner to fix the volume issue.
So...today I spent all of 14 seconds on my 996. Fixed the issue immediately. You could pretty much say I'm a master tech at this point.
If this is bothering you, go do it! Its not worth the headache when its SO easy.
Old 02-21-2022 | 11:04 PM
Fishah's Avatar
Fishah
Doja Cat, eh?
I'm intrigued! Do you have the youtube link by chance?
Old 02-21-2022 | 11:29 PM
golock911's Avatar
golock911
Awesome! and funny. Time to date ourselves. The first time I used this method to clean a rheostat on an amplifier was at school in 1983! And I'm sure the chemical in that can was not safe for the environment...
Old 02-22-2022 | 11:32 AM
plpete84's Avatar
plpete84
Great timing as this has been bugging me for a while too! I don't mind the stock Bose system at all. Will have to give this a try. Additionally, at temps below 50F my radio turns on but produces no sound. Another gremlin I need to chase down.
Randy Rossi (02-22-2022)
Old 02-22-2022 | 11:44 AM
porrsha's Avatar
porrsha
Sounds like (no pun intended) you need the can of compressed antifreeze!
TexSquirrel (02-22-2022)
Old 02-22-2022 | 11:56 AM
Coussa's Avatar
Coussa
Thanks for the trick! i don't have this issue yet but was intrigued by your shifter ****. What and where did you get it if you don't mind me asking?
Old 02-22-2022 | 12:50 PM
Randy Rossi
Thanks! Dont mind at all! I love this shift ****. Had a rennline aluminum on before and replaced with this. Makes the interior. Its a gentleman named Manual who makes them to order by hand. Going to be about twice as much as a rennline wooden, but well, well worth it and you get the option to customize. @zbomb and several others who I can't remember all have ***** from him. Check out this thread. You can see other varieties and his email address there. Ping him with what you want. He is super helpful/fast.
https://rennlist.com/forums/996-foru...n-a-996-a.html
Old 02-22-2022 | 12:51 PM
Randy Rossi
Originally Posted by Fishah
Doja Cat, eh?
Haha I knew someone would call that out after I noticed it. Just what was playing when I took the pic, I swear! hahah
Just search "volume **** contact cleaner" and you should find several videos
Old 02-22-2022 | 12:54 PM
Randy Rossi
When this has happened to me, I just key cycle the car. Has fixed it all of the maybe 3 times I've experienced it. My head unit will also occasionally get stuck on the "PORSCHE" boot up screen. Same thing; key cycle and its fixed.
plpete84 (02-22-2022)
Old 02-22-2022 | 12:58 PM
plpete84's Avatar
plpete84
Interesting! Will have to give this a try next time it happens. Not as often but I've gotten the PORSCHE logo stuck as well. Only a matter of time till I replace the unit....
Old 02-22-2022 | 03:21 PM
Coussa's Avatar
Coussa
Thanks you so much, will check it out. I am very tempted to go for a Black forest Industries but love the custom wood idea. cheers.
Old 02-22-2022 | 07:07 PM
Idaho911's Avatar
Idaho911
Okay so dumb question: The **** on the CDR23 doesn't come off, right? Did you just blast around it?
Old 02-22-2022 | 07:31 PM
Randy Rossi
Just pull gently and they come straight off. Its only plastic inside though, so no need to spray the **** itself. Just spray where you pulled it out (doesn't take much!). I wiped the excess immediately to keep the head unit clear. Give it 10 or 20 seconds then soak up any moisture you see. Should be good to go.
Old 02-23-2022 | 02:41 PM
Idaho911's Avatar
Idaho911
Will do, thanks for the info. I've pulled on them in the past and they haven't budged, but I will engage my Inner Hulk.
Quick Reply: Dont suffer! - CDR Volume Knob
