996 Forum 1999-2005
Where does this go?
Old 02-08-2022 | 01:41 PM
sur4die's Avatar
sur4die
Default Where does this go?
Pulled apart the cowl to clean up and do other maintenance. Can’t figure out where this sucker goes though?
Old 02-08-2022 | 01:42 PM
Optionman1's Avatar
Optionman1
Battery drain/vent tube
Old 02-08-2022 | 01:45 PM
sur4die's Avatar
sur4die
Nope
Dr_Strangelove's Avatar
Dr_Strangelove
Since you were near the cowl I am guessing it's part #20?
http://www.autoatlanta.com/porsche-p...section=904-10
Old 02-08-2022 | 01:47 PM
Optionman1's Avatar
Optionman1
Possibly an extra tube?
Old 02-08-2022 | 01:48 PM
sur4die's Avatar
sur4die
Not part 20. Very sure that’s installed
also had the headlights out for a polish. So could be around there as well.
Old 02-08-2022 | 01:50 PM
Optionman1's Avatar
Optionman1
I found an extra one in my frunk when I bought my 996 few years ago.
Old 02-08-2022 | 01:55 PM
Dr_Strangelove
Here are the catalogues for the headlights. I don't see anything with a 90-degree angle on these diagrams...
Mk1 headlight washer system: http://www.autoatlanta.com/porsche-p...section=904-20
Mk1 Headlight: http://www.autoatlanta.com/porsche-p...section=905-01
Mk2 headlight washer: http://www.autoatlanta.com/porsche-p...section=904-21
Mk2 headlight: http://www.autoatlanta.com/porsche-p...section=905-03
Old 02-08-2022 | 01:58 PM
wildbilly32's Avatar
wildbilly32
Spare parts for a 996!! BONUS!
Old 02-08-2022 | 02:01 PM
Optionman1's Avatar
Optionman1
What’s new in Nebraska?
Old 02-08-2022 | 02:03 PM
GoGoDoDo's Avatar
GoGoDoDo
Only thing I found, looking remotely close, was a breather pipe near headlight assembly. Even that just doesn't look close enough.
Old 02-08-2022 | 02:12 PM
Optionman1's Avatar
Optionman1
I had that exact part, it goes to the battery! It must have been replaced by the clear one on your battery but I’m almost certain that’s what it is.
Old 02-08-2022 | 03:35 PM
sur4die's Avatar
sur4die
The clear battery tube I have runs all the way to the drain hole. Which makes total sense. Otherwise I'm imagining that there's be a bunch of corrosion from the outgassing.
Old 02-08-2022 | 03:48 PM
Optionman1's Avatar
Optionman1
https://rennlist.com/forums/996-foru...mpartment.html
Old 02-08-2022 | 03:50 PM
sur4die's Avatar
sur4die
perhaps other battery models have the breather nipple that fits this tube? because it doesn't fit my current battery
Optionman1 (02-08-2022)
Quick Reply: Where does this go?
