996 Forum 1999-2005
H&R Springs on 2000 C2
Old 09-30-2021 | 08:21 PM
buford1989's Avatar
buford1989
4th Gear
Default H&R Springs on 2000 C2
I just purchased a 2000 C2 and decided to install H&R springs. I took it in for an alignment and they said it required a camber and toe kit to get the alignment into spec. Is this common? Thanks for your input.
Old 09-30-2021 | 10:39 PM
Argeo's Avatar
Argeo
Not sure about C2 but c4s required adjustable toe arms.
buford1989 (10-01-2021)
Old 10-01-2021 | 02:07 AM
barbancourt's Avatar
barbancourt
Unless you are going pretty low, I don't think this is accurate. I did use adjustable rear toe arms, but my car is on coilovers and relatively low.
Old 10-01-2021 | 02:22 AM
ninelevenick's Avatar
ninelevenick
After installing my H&R lowering springs and B8 Bilsteins, I did not have to purchase a camber and toe kit to get the car to align properly.
Old 10-01-2021 | 09:10 AM
JTT's Avatar
JTT
My 2003 C2 had to have upper control arms and toe arms to get it into a reasonable street alignment with H&Rs and B8s. If you don’t mind a more track oriented alignment (and tire wear associated), you can get away without anything.
The following 2 users liked this post by JTT:
dporto (10-01-2021), Ratchet1025 (11-08-2021)
Old 10-01-2021 | 10:25 AM
buford1989's Avatar
buford1989
4th Gear
What after market arms did you use. I found Godspeed turnbuckle arms any experience with them?
Old 10-01-2021 | 11:50 AM
hbdunn's Avatar
hbdunn
Are you referring to just the rear? On the rear if they can get the camber in spec but not the toe then you can get away with adjustable toe arms.
Old 10-01-2021 | 12:37 PM
junior23's Avatar
junior23
I confirm this. I have H&R's on my car and was able to get it aligned to Kussmaul GT3 specifications without any additional aftermarket parts. However, this specification is considered to be more track oriented.
Old 10-01-2021 | 03:58 PM
De Jeeper's Avatar
De Jeeper
Yea but thats 2.5 to 3* of camber. If u want 0-1* then u will need adjustable toe arms
Old 10-01-2021 | 08:26 PM
JTT's Avatar
JTT
...and upper control arms
Old 11-07-2021 | 09:19 PM
buford1989's Avatar
buford1989
4th Gear
Installed turnbuckle control arms and now it is aligned.
After H&R springs.
The following 2 users liked this post by buford1989:
dporto (11-07-2021), Ratchet1025 (11-08-2021)
Quick Reply: H&R Springs on 2000 C2
