'99 Cab top stuck
'99 Cab top stuck
So, I have a 1999 996 Cabriolet, and the top will only go halfway down and stop. hydraulic level is good. I can disconnect the dog bones from the top to the hydraulic cylinders, and the top will lay down into it's compartment nicely, its just that the hydraulic cylinders only operate halfway. Any ideas?
Have you checked the positioing potentiometer located on pasenger side below rear window? If you know someone with a Durametric, it can tell you right away if it is faulty. Where are you located?
