996 Forum 1999-2005
Anyone know how to fix the piece that the cabrio top latches to?
Old 08-02-2021 | 09:53 PM
motoo344's Avatar
motoo344
Default Anyone know how to fix the piece that the cabrio top latches to?
I usually don't even leave my top up but someone pointed out that my top was not completely closed. I noticed that when the top closes and latches it pulls the latch forward on the left, driver side. When the top is closed or unlatched the dome piece sits where it's supposed to. Does anyone know what's going on here and how to fix it before I just start ripping it apart?
Old 08-03-2021 | 11:06 AM
frisbee91's Avatar
frisbee91
Things are looking very crooked there. But it's hard to see what's going on. Try posting up some pics of both parts of the mechanism with the top halfway open?
Old 08-03-2021 | 11:16 AM
motoo344's Avatar
motoo344
Right, it's only crooked once the latch locks itself. If I put the top down it looks fine.
Old 08-04-2021 | 11:14 PM
Makoto0406's Avatar
Makoto0406
There are like four bolts that keep the latch receptacle in place. My guess is one or more of them are loose allowing the unit to be torqued when the top latches in. I’d open the top and gently pry off the cover and see what’s up.
M
HoustonCgrBkr (08-05-2021)
Old 08-05-2021 | 10:49 AM
motoo344's Avatar
motoo344
M
Thank you, any idea how to remove that piece?
Old 08-05-2021 | 11:07 AM
motoo344's Avatar
motoo344
I figured it out. It was really easy in case anyone runs into the same thing. There are two T30 screws under the black caps on the dome light. Mine must have fallen out a while ago for some reason and I never figured out what it was for because it was sitting in my storage space under the radio. The torx screw on the other side was also loose, tightened them both backdown and as good as new.
Old 08-05-2021 | 11:17 AM
Makoto0406's Avatar
Makoto0406
Glad your back up and running. My bolts had red locktight on them. You might want to consider that
M
motoo344 (08-05-2021)
Old 08-05-2021 | 03:05 PM
motoo344's Avatar
motoo344
M
I will check that out. I remember it falling out and I had no idea what it was for. It must have come loose over time from latching but it only recently started to get crooked like that, must have been because the other side was finally coming lose, glad I caught it before the latch ripped it off.
Old 08-05-2021 | 05:12 PM
Yogibara's Avatar
Yogibara
Definitely Loctite. What’s weird is that the repair manual says only 7NM to tighten them. 15nm makes more sense. I’d also do a one over on your entire system. If you see leaking in front of your real wheels the rams may be in need of a rebuild.
I did a whole repair series on these tops on my YouTube channel.
Quick Reply: Anyone know how to fix the piece that the cabrio top latches to?
