996 Forum 1999-2005
Low miles or Higher miles?
Old Jun 13, 2021 | 12:34 AM
rmikebaker's Avatar
rmikebaker
Default Low miles or Higher miles?
Long-time Porsche window shopper, but getting more serious about a 996.
Question.... Would it be better to target a lower mileage vehicle and pay more up front, or go with a higher mileage vehicle that's less expensive? A lower mileage vehicle may not have had the critical maintenance performed (IMS/RMS), but the same could be true of a high-mileage vehicle. If I get a high-mileage vehicle, would I be better served to just drive it until something goes wrong (still doing regular maintenance, of course), or just go ahead and perhaps have the engine rebuilt to get a good start. With some of the prices I've seen for high-mileage 996's, there'd still be plenty in the piggy bank to fund an engine rebuild.
Thanks in advance for your insight.
Mike
Old Jun 13, 2021 | 12:43 AM
EVOMMM's Avatar
EVOMMM
PPI for any car is your friend regardless of mileage my car I bought had 98k when I bought it I’ve been lucky so far but….. you never really know
Mike
Old Jun 13, 2021 | 01:01 AM
Brian_C's Avatar
Brian_C
Go for the higher mileage then fully appreciate the eventual 4.0 build!
either way take the prospect to a shop and have them perform a cylinder bore scope from the the bottom via sump plate (opposed to top side via spark plugs). Low and high mileage 996’s should be checked for bore scoring. It’s the most costly issue these days.
Old Jun 13, 2021 | 01:15 AM
GC996's Avatar
GC996
Welcome to the awesome world of the 996!
High or low mileage isn't as important as the service history of the car and performing a PPI including checking for bore scoring with a scope.
If the seller has taken good care of the car, he/she will have the service records and you can see how many rear main seals were replaced, intermediate shaft seals, intermediate shaft bearings, AOS, water pump, rubber/plastic parts under the hood, etc, as well as how often the oil was changed and when, as well as what oil was used.
These are critical items that if they haven't been taken care of previously, regardless of the miles, can and will create problems and can lead to the need for a 20-30k engine rebuild sooner than later. A rebuild is inevitable with a 20 year old engine. But many of us would like to keep the engine running in top shape, so we can choose what we want for a rebuild and when; instead of a surprise implosion before we are ready.
I have had my 02 C2 for 19 years and am doing a project every year to replace worn parts with new so I can enjoy it for another 20 years. It's not the cost to buy the car, it's the cost to keep your classic Porsche running in top form.
Hope this helps.
Edit Add: forgot to mention Fuel Injectors, Ignition Coils, and sensors, as other things that you need to look for in the service records as to have been replaced.
Old Jun 13, 2021 | 01:21 AM
Phiphe's Avatar
Phiphe
I've bought 3 ultra low mile , one a 20 yr old 996, a 10 yr old 85 turbo and and a 4 yr old 89 targa. zero issues other than normal maintenance. Also had a new 04 996 for 16 yrs with original imsb and zero issues other than oil change. PPI is your friend as stated above.
Old Jun 13, 2021 | 09:52 AM
JP_Gervs's Avatar
JP_Gervs
Sorry to hijack thread, I am in the same situation....how much should I be concerned about bore scoring in a 2003 C2 with 31k miles? PPI did not perform compression test or bore score check, but he did say no metal in oil at all. This PPI shop I hired is a Porsche specialist. Should I have a second PPI at a different shop just for bore score and compression?
Old Jun 13, 2021 | 09:54 AM
GC996's Avatar
GC996
Have you seen the service records?
Old Jun 13, 2021 | 10:04 AM
JP_Gervs's Avatar
JP_Gervs
CarFax does show service, but nothing in the form of detailed records from the dealer selling the car.
Old Jun 13, 2021 | 10:16 AM
GC996's Avatar
GC996
The reason I ask is that
There are a lot of things that can cause bore scoring of which you can search RL on the topic. FSI and LN engineering have done a lot of videos on the topic. Such as high ethanol content gas, garage queens that are not properly driven but instead started, idled, moved and then parked again. Not replacing Ignition Coils, fuel injectors, sensors. Never changing the oil. Porsche says 15k miles which is ill advised imho. So you may only have 2 oil changes in 20 years. Not good for oil or engine. The more oil changes the better. Not doing the Porsche service schedule with replacements parts, especially after 20 years.
PPI with bore scope or worst case oil testing beyond checking for metal certainly helps to identify if there is an issue. You get the idea. Service records will tell you how well cared it has been. Remember, most people are cheap, especially with car service, and 20 year old garage queens can very well be underserviced and at risk without knowing it.
Not saying any of this to scare you. I drive mine around town and have tracked it since 2004. Never had any engine problems, nor show any bore scoring issues. But I have serviced the he'll out of the car for nearly 20 years and am obsessive about oil changes, not to mention did all of the preventative things I could do early to prolong engine life. It's an awesome car that I will never get rid of.
As I said earlier, it's not the cost to buy the car that is expensive, even with rising prices. It's the cost of maintaining the car so it's in top shape mechanically. Most owners have failed regardless of high or low mileage.
Old Jun 13, 2021 | 10:29 AM
JP_Gervs's Avatar
JP_Gervs
It does have original ignition coils and plugs. Or at least the "old style" coil packs, which led PPI to believe they are both original parts. At 31k miles, that's less than 3k per year since new.
If I can't obtain service history, should I opt for getting bore scope checked ? Should I do it anyway for peace of mind? I think so. They also noted oil was in good shape, not super dark. He said that if there were scored cylinders bores, there would be other signs or symptoms in which he would see? It is my understanding this is NOT the case, and just like IMS, there's no way to check without getting inside?
Old Jun 13, 2021 | 10:33 AM
GC996's Avatar
GC996
​​​​​​Look at it this way. If all the service has been done properly with all the replacement parts including IMS, RMS, AOS, Fuel Injectors, Coils, Spark Plugs, Sensors, constant oil changes, and there is proven to be NO bore scoring, there is a pretty good chance that your engine will last quite awhile longer before you will need a 20-30k rebuild.
If none of these things have been done, and it turns out you have bore scoring, you will need to spend 20-30k sooner for a rebuild.
Regardless, it's a 20 year old car and a rebuild will eventually need to be done. It may be next year or it may be in 7 more years. Just factor that into your planning. The good news is that they aren't making any more 996s. Certainly helps with future prices and your willingness to spend the money servicing the car in the future.
I would buy mine all over again, for the same price I paid in 2002. Plus put all of the money into servicing it all over again. Why, because it's an awesome car.
Edit Add: Water pump replacement is critical.
Old Jun 13, 2021 | 10:40 AM
JP_Gervs's Avatar
JP_Gervs
Yeah, I'd rather do that later than sooner!! Thanks.
bmchan's Avatar
bmchan
I watched a Jay Leno You Tube episode last night and he was asked if he preferred low mileage cars and he replied that oil is like blood and it needs to be circulating to keep the car in good health - he likes higher mileage cars that show regular use.
Mike
Old Jun 13, 2021 | 10:52 AM
JP_Gervs's Avatar
JP_Gervs
Also, I may add that the shop I used for PPI, was phenomenal, and I would certainly use them again. But the discrepancy here is in the fact that my local shop says bore check and compression test are crucial, and the PPI shop I used, says he rarely sees compression or bore scoring without any accompanying signs, and kind of made it like its OK not to check.
Old Jun 13, 2021 | 12:30 PM
Putt-Putt's Avatar
Putt-Putt
Mike
One data point: The local Porsche expert mechanic where I live is of the opinion with the 1999 996 that you should get the lowest mileage car you could find that passes a stringent PPI. Also, don't track it or you will tear it apart. Drive it in the 3-5K rage with occasional fun jumps to 6000'ish. Oil change every 3000 miles and check for signs of IMSB degradation, otherwise no need to change the bearing until the clutch is needed, which should be way down the road on a properly driven and maintained car.
Chose to follow his advice. Got mine Jan 2021, 27.5K miles, good records, mature previous owner, Only 200 stage 1 revs, maintained for years by Porsche specialists High-Tec Auto, California car all its life, extensive PPI - passed with flying colors. $29K, semi special color - Glacier White. So far has worked out great..
