996 Forum 1999-2005
Fueling Issue
Old Jun 10, 2021 | 02:48 PM
langg's Avatar
langg
Default Fueling Issue
Hi everyone.
2001 C4 Coupe 6 speed. I started with a fuel reading problem. Gauge read ok with Duramentric otherwise read empty. I swapped out the sending unit. Still read zero. Started over.
Now:
Tank is empty.
New sending unit
Battery disconnected.
I want to put in 7.3 gallons of fuel. I can not get gas in tank. It runs back out the fill port.
What's up?
Lang G
Old Jun 10, 2021 | 03:12 PM
DBJoe996's Avatar
DBJoe996
Did you reconnect the battery? The fill valve solenoid is electrically operated.
Old Jun 10, 2021 | 03:23 PM
langg's Avatar
langg
Therein lies part of the problem. I want to connect the electricity when the sender is plugged in and there is 7.3 gallons in the tank. But maybe that is not possible.
Old Jun 10, 2021 | 06:57 PM
NuttyProfessor's Avatar
NuttyProfessor
Originally Posted by langg
Hi everyone.
Now:
Tank is empty.
New sending unit
What's up?
Lang G
I was having the same problem. Thought it was the fuel vent system in these cars. I would take it to the same Shell gas station because the 93 V power gasoline is what Jake Raby recommends for our cars, but every time I would try to pump gasoline in the 996, it would click off. Frustrating! I started going to a different station and didn't have the problem anymore. What could be the problem the car?
