996 Forum 1999-2005
Metal dust in oil
Old 11-25-2020, 07:41 PM
  #31
Boston4
5th Gear
Boston4's Avatar
Originally Posted by NuttyProfessor
When I was researching the problem associated with bearing failure, several unfortunate owners posted pictures with a power dusted filter like what you shown. Once they removed the IMS flange and outer seal, this metal powdered substance was also caked around the inside of the bearing and probably circulating all throughout the engine judging what was found in the filter. Most of the engine expects said replacing the bearing and "flushing the system" would not prevent engine failure.
See emphasized - is that the current consensus? If you get to the point where you catch silver metal in the oil similar to the OP then the engine is terminal as a result and you might as well not bother replacing the bearing or trying to save it?
Old 11-25-2020, 08:00 PM
  #32
ZuffenZeus
ZuffenZeus's Avatar
Received 1,921 Likes on 1,050 Posts
IMHO, it's best the engine is fully rebuilt and have all parts addressed.
We have a strong consensus that many shops have installed new bearings in failing engines. Even with engines that are still operational, but metal contaminated from a previous failing bearing. This is why Jake Raby requires pre-qualification from certified installers and strongly recommends it to all DiYr's. They have found that installing a fresh IMS bearing in a Porsche engine that is contaminated with metal will not only take out the new bearing, but the engine with it. No winners when that happens... it hurts the owner, the shop's reputation, the bearing manufacturer as well as the patent holder (i.e. Jake Raby).
Old 11-25-2020, 08:32 PM
  #33
Boston4
5th Gear
Boston4's Avatar
Yeah, I’m familiar with the pre-qual requirements for the LN bearings and IMS solution - was just curious about experiences from others.
I’m sure that many owners have found metal in their oil, replaced the bearing and flushed the oil, and then either sold the car or kept it. There are a tons of used 996s on the market with aftermarket bearings - no way to tell if they were replaced proactively or reactively, though.
Old 11-25-2020, 09:12 PM
  #34
85eurocarrera
85eurocarrera's Avatar
I kept mine for just this reason....
Quick Reply: Metal dust in oil
