996 Forum 1999-2005
Tag Light and Reverse Light not working
Old Nov 2, 2020 | 12:19 PM
johnalaska's Avatar
johnalaska
Default Tag Light and Reverse Light not working
I just noticed both are not lighting up and wondered if anyone had a similar problem...both fuses are ok.
Old Nov 2, 2020 | 12:55 PM
DBJoe996's Avatar
DBJoe996
Take out one of the tag lights and check for 12V. You have to have the headlights on for the tag lights to work. If you have 12V, check for continuity to ground. There is a common ground point back there, I just don't remember where. Might be under the air filter box or on that back metal shelf.
Old Nov 2, 2020 | 05:23 PM
johnalaska's Avatar
johnalaska
Thanks there is no current at the tag lights...is there supposed to be a ground wire attached somewhere back there or maybe inside the rear bumper cover?
Old Nov 2, 2020 | 05:38 PM
DBJoe996's Avatar
DBJoe996
There is a plug for the tag lights behind the rear bumper cover. You basically have to remove the bumper cover to get to it. That doesn't explain the reverse lights, but that could be the reverse switch on the transmission.
Old Nov 2, 2020 | 05:58 PM
johnalaska's Avatar
johnalaska
That's what I was afraid of...thanks!
