I'm noticing some clutch slippage under power in the higher gears, and this is disconcerting on my 2000 996 Cab. The car only has 58,000 miles and a new clutch and flywheel were done 5000 miles ago. The car is a weekend driver and is not thrashed as I'm not a kid anymore. Any suggestions as to what the matter can be?
Check for freeplay! If the clutch pedal is firm with no "Slack" you'll have slippage. Bob
And be sure that the slippage is measured at the right spot. If measured by the person’s foot, it could be tight due to the helper spring on the clutch pedal, so that’s not the contact point to check. Just an FYI.
