Code P0507
May 29, 2020 | 03:18 PM
Code P0507
Quick question. I’ve been getting a P0507 alarm code. Kinda annoying. I clear it and it comes back 20-30 miles later. It’s a high idle alarm and says it could be a vacuum leak. Has anyone else had this problem? If so, is there a common place where this leak occurs or am I on a wild goose chase till I find it? Thanks
May 29, 2020 | 04:25 PM
Easiest way to find a vacuum leak if you cannot hear it, is a smoke test. Cheap smoke kits can be found on fleabay.
Greg.
May 29, 2020 | 06:30 PM
Oil fill tube cracks. There r also several rigid vac lines that crack. Just do a search for the diagrams
May 29, 2020 | 06:40 PM
Quote:
Originally Posted by
De Jeeper
I do have a broken oil filler tube. I have a new one to replace it. I got it all sealed up temporarily. Evidently not good enough?
May 30, 2020 | 02:01 AM
Had this code in our boxster....in our case it was debrie in vacuum line.
May 30, 2020 | 10:17 AM
RL Community TeamRennlist Member
mwiebz
Since the oil fill pipe has a tendency to crack on the corrugated part, very difficult to seal it. It is probably the source of your problem.
May 30, 2020 | 10:22 AM
mwiebz
