Convertable dash switch not working
Dash switch works neither up nor down?
What about if you operate the top half way using the door method, then stop. Now, get in, start it, and see if it will move with the switch in either direction. This could rule out one of the many micro switches in the system.
Alternatively, you could pull off the dash "horseshoe" and try to jumper the switch to see if that works.
