Girodisc Brake Pads Grinding
Disclaimer: I installed new pads on my C63 but I came here because you all are so knowledgeable and I got nothing from the C63 forum. And, brakes are brakes, right?
I have Girodisc pads and rotors. I swapped out the old pads for new Girodisc pads. Straightforward install—in fact, the rears went on easily. Now, after a few miles and a dozen brake applications, I get a grinding sound when stopping from like 5-10 mph to 0. I set the parking brake and pump the brakes a couple times and it goes away for a couple of stops then it’s back.
i didn’t bed the pads per Girodisc recommendation.
The performance otherwise is flawless. Any ideas?
Thanks all!
TC
Thanks all!
TC
Thanks all!
TC
Thanks all!
TC
Yes but I had to play whack-a-mole to get them to fit. When I pushed one in too far another would pop out and block the pad.
TC
TC
