Preventative turns to fix
Took car to get brake fluid flushed this morning. $150, not the end of the world.
Now I am going back next week to get oil return tube fixed and replace front differential seals on 4S. With alignment, $1,700. 1st big expense in the 9 months of ownership. Excluding replacing IMSB, clutch, coolant tank, and water pump.
Amazed my wife hasn't divorced me.
It helps a lot if you can do at least some of these jobs yourself (all the ones you've listed are easily doable with basic tools) and give the savings to your wife.
Very true. A man must know his limitations though.
^^Yes^^ The wife being a major one...![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
In my case my wife says “spend more time with me, pay someone to do the work”. Since she made me buy my 996 when i was just considering buying one, who am i to argue. Happy wife.....
Weird, In my case the wife has gotten a not more carefree with the spending with the 996. With the Boxster S and 77 C3 (both sold), not so much. Maybe I have worn her down.
Optionman1 (04-17-2020)
What is the issue with the oil return tubes?
Wayyyy to many folks on this forum devalue the experience, skills and specialty tools that a professional Porsche mechanic brings to the table and think everything is DIY. This is simply not true.
Return tube is cracked. Not yet making the car run funny but oil visible. Surprised I didn't see the oil change at all. Car still runs and drives great.
I hope it's just seals. Shop said it could lead to bad things happening down the road. Guy is good and I feel trustworthy. Heck I told him to replace the alternator since removing with the oil tube. Told me it looked new. Leave be.
I personally envy these guys. Worth every penny.
Captain Obvious
Super User
Super User
My wife has no problem if I spend time working on the cars, as long as it doesn't cost too much money. How much time do you really need to spend with your wife? Instead of watching the Hallmark Chanel with her, go work on your cars.
The following 2 users liked this post by Imo000:
dporto (04-17-2020),
SoundnSpeed (04-21-2020)
Leaking differential front seals is a sign of failure, hence the seals and bearings should be replaced. Otherwise you will be in a world of financial pain if that front diff fails. I don't see how this is very doable with basic tools and no experience. Even experienced Porsche mechanics have had to do this job twice because the customer brought it back because it was leaking again. There is no savings doing this job yourself, better off to pay somebody.
![Roll Eyes (Sarcastic)](https://rennlist.com/forums/images/smilies/rolleyes.gif)
The following 2 users liked this post by dporto:
jjbravo (04-17-2020),
wildbilly32 (04-18-2020)
I have to agree with "dporto" on this one, way too many horror stories about "professional Porsche mechanics" and some of the shoddy work they've performed on unsuspecting/trusting customers' cars. I am not suggesting they are all bad, but there are enough bad ones, including dealerships, to make it a crap shoot which can be a hell of an expensive lesson. Personally, the best thing I ever did automotive wise was liberate myself from having to rely on someone else to repair/maintain my cars.
dporto (04-17-2020)
Leaking seals are typically followed by bearing failure due to lack of oil/lubrication. Both the seals and the bearings should be changed. Yes, mechanics sometimes make mistakes and have to redo a job. However, other times they don't make a mistake but the job has to be redone due to a defective part that they installed. Sure, anybody can attempt to do any job they want, but that doesn't mean it's always a money saver.
Many of the DIY posts on this forum read:
"Very frustrated, just changed my clutch and now it won't go into gear. Now I have to redo this again. Aaarrrghhh".
"Just put in new coilovers twice and I still have a bad clunking sound"...
"Need advice, tried to change my spark plugs and one shattered inside the cam covers"...
"Help! I rebuilt my power steering rack and it still leaks"...
Lot's of people post here how easy doing these jobs are and if you tackle them yourself you will save a bunch of money. But that is not always true.
DIY is great, but not always worth it.
dporto (04-18-2020)
- abilities - fairly obvious, but the learning factor of doing things yourself cannot be over emphasized. So many people own these cars and know absolutely nothing about them, it is amazing
- facilities - if all you have is a gravel driveway to work in, this becomes a problem for some jobs admittedly. Tools are also a factor. Tools to me are an investment. I’ve got tools I purchased 40 yrs ago and still use today.
- disposable income - this one is obvious. If you’ve got lots of disposable income, don’t care to get dirty, or want to learn anything about the car, there are lots of $150/hr mechanics that will add windshield washer fluid for you.
- enjoyment factor - I personally enjoy wrenching on my car. It’s my zen time. Plus I like the independence of it. I’ve always been extremely independent and like to be able to manage on my own (with a little help from friends periodically - like Rennlist)
