996 Forum 1999-2005
Open front Hood 02 986
Old 04-09-2020 | 11:04 PM
ValleyPorsche's Avatar
ValleyPorsche
2nd Gear
Default Open front Hood 02 986
Battery under hood is disconnected, took off passenger side tire and cannot find wire to open the hood at all. Is their anyway to open front hood without the battery being connected? Will connecting a jumper still work?
Old 04-10-2020 | 01:48 AM
Prelude Guy's Avatar
Prelude Guy
Are you able to jump it at the fuse panel in the driver's footwell? That would be the easiest. It has a + post in there to power the car.
Old 04-10-2020 | 02:39 AM
ValleyPorsche
2nd Gear
will it still work even though the negative battery cable on the battery is disconnected ?
Old 04-10-2020 | 08:45 AM
Prelude Guy
Yes. You're just adding power from a different location.
You can clamp the negative terminal to the door hinge in the door jam.
Quick Reply: Open front Hood 02 986
