Durametric
Durametric
Acquired a Durametric Pro along with recent 997.2 but haven’t used it yet as i don’t have a windows laptop (tomorrow). Read the users guide, seems straightforward, not a mechanic, so basic questions:
On my 996.2, which isn’t experiencing any issues nor has CEL ever come on, should i just run a Short Test and see what develops? On an ongoing basis do i perform Short Tests periodically or only when experiencing issues/CEL?
I don't know how it is with Porsches but with my Audi's I can scan my car with OBD 11 and VAGCOM will show any faults even if it doesn't throw a code. Like my center air vent motor locked, doesn't throw a light but will show up in the faults under the HVAC system. So if Porsche is the same way it might be worth a look to see if anything is going on.
Optionman1 (03-14-2020)
motoo, when i get it working maybe we can work out a swap. Pro version gives me unlimited Porsche connections vs 3 with enthusiast version.
Owner’s manual did mention test reporting items that won’t throw CEL but otherwise are “informational”.
motoo344 (03-15-2020)
Play with it now and log your results.
Then you’ll know what a good running engine looks like.
Porschetech3 (03-14-2020)
Check out one of Flat6 Innovations videos on YouTube. I'm not sure which one it is, but it gives some good things to check with a Durametric.
Edit, found it:
Edit, found it:
The following 2 users liked this post by wyovino:
911STYL (03-15-2020),
Optionman1 (03-15-2020)
Might my cable be screwed up?
I just checked over-rev's for my '99 996 with 53k miles. Zero range 2 ignitions. Whoop!
A bit of math based on the Durametric numbers:
Also pleased that Durametric confirmed the cam deviations are within 3 degrees, but I knew that already from my indy...
