Gauge lights will dim and the radio will cut out for a microsecond when the secondary air pump comes on during normal operating temps. Suggestions? Thanks!
Deff not normal. I suspect a bad ground or maybe a poor fuse connection? The sai pump is dawing way too much power at start up and droping the voltage. It may be going bad. Check the sai connector too.
