996 Forum 1999-2005
Self healing AOS?
Old Mar 1, 2020 | 07:54 PM
TexSquirrel's Avatar
TexSquirrel
Default Self healing AOS?
So I have an electronic manometer and have been monitoring my AOS every few months.
The first few times I tested it was well under 5”H2O.
Then the next time it read a little under 7”.
Someone suggested I change the battery and retest.
Last time, after a new battery was installed, was back in November of last year and it reached nearly 9”.
I’ve been putting replacement off, and then decided I’d wait for @Porschetech3 ’s UAOS.
When I tested it on Friday after a 35 mile commute, it read 4.94”.
I’m going to retest after my commute tomorrow.
What could cause an AOS to fail, and then un-fail?
Maybe I need to test the old fashioned way with a slack tube.
Old Mar 2, 2020 | 03:06 AM
pdxmotorhead's Avatar
pdxmotorhead
Mine failing cost me the engine.. Ya takes your chances..
Old Mar 2, 2020 | 10:47 AM
Imo000's Avatar
Imo000
Captain Obvious
Super User
Cars don't heal themselves. If you AOS showed signs of failing, it will not magically fix itself. I fit happened ones, it will happen again. Your car is trying to tell you something, make sure you listen.
Old Mar 2, 2020 | 10:51 AM
Scott at Team Harco's Avatar
Scott at Team Harco
Just a car guy
Did you test under identical conditions? I.e. the same amount of driving and everything up to temp?
Old Mar 2, 2020 | 11:04 AM
808Bill's Avatar
808Bill
Mine is (Scott caught me again) all over the place and I'm not sure if my Manometer is even working properly.
Old Mar 2, 2020 | 11:36 AM
Coopduc's Avatar
Coopduc
Maybe you have an intermittent vacuum leak somewhere else in the system that causes erratic readings ??
Old Mar 2, 2020 | 11:38 AM
Scott at Team Harco
Just a car guy
Originally Posted by 808Bill
Mines all over the place and I'm not sure if my Manometer is even working properly.
I had to read this a couple of times. This is what came to mind, first...
Old Mar 2, 2020 | 11:39 AM
Scott at Team Harco
Just a car guy
There you go, using rational thought.
Old Mar 2, 2020 | 11:41 AM
dporto's Avatar
dporto
Maybe you should try a Ladyometer... it may treat you better
Old Mar 2, 2020 | 11:51 AM
Coopduc's Avatar
Coopduc
I hate it when that happens. I’ll go back to jackass mode now.
There are little blue pills that can help with that...I mean I’ve been told!
Old Mar 2, 2020 | 11:53 AM
Scott at Team Harco
Just a car guy
Don't try to muscle in on my territory.
Old Mar 2, 2020 | 12:13 PM
sweet victory's Avatar
sweet victory
I agree that an intermittent issue would be more likely than self healing. Hopefully @Porschetech3 could chime in, or you could bring it up in his AOS Solution thread.
Old Mar 2, 2020 | 12:28 PM
808Bill's Avatar
808Bill
Yup, the m96 is loaded with mines!
Old Mar 2, 2020 | 12:30 PM
808Bill's Avatar
808Bill
That crossed my mind (see that Scott). Might be the old oil fill cap I used.
Scott at Team Harco
Just a car guy
Or if you are accessing the site on your phone and using the tiny little "keypad", inserting an apostrophe is a pain in the ***.
