996 Forum 1999-2005
Fister Hack Cross Pipe Configuration Question
Old 01-26-2020, 03:39 PM
Jengah
Jengah's Avatar
Default Fister Hack Cross Pipe Configuration Question
This is NOT a post about which is better (Fister or Gundo)....
Does anyone know why Fister uses a curved piece of pipe for the cross pipe as opposed to a straight piece?
Straight Pipe Photo:
Fister w/ Curved Pipe:
Old 01-26-2020, 05:30 PM
sweet victory
sweet victory's Avatar
I don't own a fister muffler, but if I were to weld this myself, I would have to use the curved piece if I wanted a larger diameter bypass pipe. If you notice in your first pic, that pipe barely fits, and I would be suspect of the weld between the pipe and the housing of the muffler. Using the curved pipe gives you room for a better rod angle and therefore a better weld. Additionally, you can get a tighter joint welding the pipe to the side. If you had a perfectly coped pipe, it wouldn't fit as shown in the first picture. All in all..one looks like it was welded by an amateur, and the other was professionally done.
Old 01-26-2020, 05:55 PM
SKM
SKM's Avatar
I believe Fister uses a 1.75" diameter bypass pipe and the curved pipe is probably easier to weld.
Old 01-26-2020, 06:00 PM
cdk4219
cdk4219's Avatar
As above , welding access is easier with the curved pipe, and cutting the holes in the existing pipe is easier at that angle. The first one looks like you have to cut one pipe off the muffler and weld straight pipe on to it, cut hole in other pipe, weld pipe with bypass back to muffler and then weld bypass to other muffler pipe. Curved pipe drill 2 holes, insert curved pipe, weld.
Old 01-26-2020, 06:18 PM
Jengah
Jengah's Avatar
I beleive you are both right. This was my hunch, but just wanted to see if anyone knew for sure. Thank you.
Old 01-26-2020, 07:54 PM
SKM
SKM's Avatar
It is not necessary to remove an inlet or outlet pipe to weld a straight pipe. A local shop installed 1.75" stainless with TIG welds and it came out quite well.
Old 01-26-2020, 10:16 PM
Mike Murphy
Mike Murphy's Avatar
Received 1,699 Likes on 1,051 Posts
Agree with the posts that say ‘it’s easier.’ The shop that did mine straight said it was a pain in the -ss and took a couple hours all-in.
Old 01-27-2020, 11:04 PM
Skyman911
Skyman911's Avatar
My shop did mine with 2" pipe.
Mike Murphy (01-27-2020)
Old 01-27-2020, 11:24 PM
Jengah
Jengah's Avatar
Apparently, the larger diameter the tube, the deeper and richer the exhaust note. Smaller = raspier. Can anyone attest to this?
Old 01-28-2020, 08:38 AM
Mike Murphy
That’s a tough one to figure out. Given how small these pipes are, I don’t see how it would make a difference on tone. I would think a larger pipe might be a little louder, though.
Old 01-28-2020, 10:37 AM
SKM
SKM's Avatar
A 1.5" cross pipe just less loud, not raspier. Borrowed a set with 1.5" from a friend. Better than stock but not as good as 1.75".
Old 01-28-2020, 12:18 PM
stancedeuros
stancedeuros's Avatar
As a hobby welder, I feel like this is the smartest/cost effective option by having the pipes "outside" the bends. Did you have any rubbing or extra heat hitting the inside of your bumper? Do you have a sound clip somewhere or video showing it installed. I think I want to do 2" piping as well.
Old 01-28-2020, 12:38 PM
Jengah
Jengah's Avatar
A smaller pipe makes it harder for gasses to pass through, thus forcing the majority of the gasses to flow into the baffled chamber. The other thing to realize is there is no standard for the size hole that is cut into each pipe to accommodate the bi-pass pipe. Thus, I've looked at a lot of photos of people doing this themselves and I've seen 3/4" holes cut with jagged edges left to be fitted with a 2" pipe. Conversely, I've seen very clean 1.5" holes to accommodate 1./75" pipes. I'd say the latter would be louder. Just my non-scientific reasoning.
Mike Murphy (01-28-2020)
Old 01-29-2020, 12:06 AM
Skyman911
Skyman911's Avatar
There is about 1/4 inch between the tube and the heat shield. No rubbing. I've taken temp readings of the outside fender and have noticed no increase in heat compared to the stock configuration. I just sold my car on Friday so I don't have a sound clip unfortunately. Upgrading to a 996TT. The sound was awesome at WOT.
Old 01-29-2020, 01:52 AM
pdxmotorhead
pdxmotorhead's Avatar
The bend allows the fish mouth of the crossover tube to nicely hit the tubes they are to be welded to.
If it was straight,, it would be harder to get a nice all around fit before welding. Just my 2 bits..
Quick Reply: Fister Hack Cross Pipe Configuration Question
