996 Forum 1999-2005
Engine swap automatic to manual
Old 01-14-2020 | 08:30 PM
Brad Magnus's Avatar
Brad Magnus
6th Gear
Default Engine swap automatic to manual
Hey all! I’m eyeing an IMSB failed engine project car. I’ve never owned a Porsche but since I was a teenager loved the 996. Anyway, I’ve also been looking for an engine for said project car.
My question is there any reason I couldn’t buy an automatic transmissioned car at salvage and swap it out?
Old 01-14-2020 | 09:25 PM
Capt. Obvious's Avatar
Capt. Obvious
If you're asking if you can swap an engine from an auto car into a manual car, the answer is yes, no biggie.
If the question is can you convert an auto transmission car to manual, the answer is essentially no (yes, you CAN, but you'd want to buy a complete manual parts car in order to pull it off so it would be cost prohibitive).
Old 01-14-2020 | 09:29 PM
Brad Magnus
6th Gear
Yes the question is about the engine only. I hadn’t seen anything that would have made me think it was a big deal, but being new to the car I wanted to check.
thanks for the response!
Old 01-15-2020 | 02:30 PM
moburki's Avatar
moburki
Pay attention to the years of the said donor engines. Engines are not all compatible year to year. Should all be searchable on this site if you are not familiar with the differences.
Old 01-15-2020 | 03:43 PM
Brad Magnus
6th Gear
Thanks for pointing that out! How is that delineated? All 996's are on the M96 platform right? Not sure how to search for compatibility.
Old 01-15-2020 | 03:50 PM
Capt. Obvious
The main difference is the 3.4 liter vs the 3.6 liter motor (99-01, and 02+).
Also, the '99s had a cable throttle instead of drive by wire. If I recall correctly, that doesn't matter as long as you have the parts needed to match your car (meaning, the throttle body and whatnot from the DBW car if you get a '99 engine).
Old 01-15-2020 | 03:51 PM
808Bill's Avatar
808Bill
98-2001 3.4 (also the throttle cable on 98, 99)
02-2005 3.6
What year is your car?
Old 01-15-2020 | 04:10 PM
Brad Magnus
6th Gear
Thanks!
The car is a 2000 and the donor is a 2001. I had been looking at 3.4L only. So that's good to know!
Old 01-15-2020 | 04:14 PM
Capt. Obvious
You know, as a guy named Magnus with a non-running Porsche in your future, I feel it was a missed opportunity on your part to not choose "Magnus the Walker" as your user name.
808Bill (01-15-2020)
Old 01-15-2020 | 04:15 PM
dporto's Avatar
dporto
^^^With the exception of the '99 C4 which was already drive by wire...
Old 01-15-2020 | 04:16 PM
Brad Magnus
6th Gear
LOL! I totally missed that opportunity didn't I?
Old 01-15-2020 | 04:18 PM
Brad Magnus
6th Gear
Thank you for this btw!
Old 01-15-2020 | 04:20 PM
808Bill's Avatar
808Bill
Make sure to address the known weak spots before installing the new motor. Vacuum lines and any hoses, clutch, Pilot bearing, DMFW, O-rings on the Heat exchanger, case bolts, RMS,AOS, WP, T-stat and IMSB. These are things you don't want to do after installation. I'm sure I forgot something...
Old 01-15-2020 | 08:48 PM
Dharn55's Avatar
Dharn55
Vario Cam engines are swappable to other Vario Cam cars. Vario CamPlus engines are swappable to other VarioCamPlus cars. Putting a VarioCamPlus engine in a VarioCam engine and vice versa is much more complicated.
Quick Reply: Engine swap automatic to manual
