996 Forum 1999-2005
Airbag LIGHT just came ON
Old 01-15-2020 | 02:50 PM
Imo000's Avatar
Imo000
Captain Obvious
Super User
Originally Posted by bamaboy473
WD40 in both seat belt sockets, pressed the multi-connects to both seats, no change. I haven't gone to get the ECU re-flashed and codes cleared, so that's next.
You don't reflash the ECU. You reset the Airbag module.
Old 01-15-2020 | 05:53 PM
pszikla's Avatar
pszikla
Almost certainly the seatbelt buckle and ultimately you will have to change it. Cleaning with WD40 rarely works as a lasting solution.
It was a factory defect and there was a TSB bulletin for this a long time ago. Porsche recommended changing the buckles and sometimes
the harness as well.
Eventually had to change mine many years ago and no recurrence since.
Old 01-16-2020 | 03:55 PM
frisbee91's Avatar
frisbee91
Mine has lasted many years. Used electrical contact cleaner though, not WD-40.
Old 01-17-2020 | 10:38 AM
dporto's Avatar
dporto
^^ Caig De-Oxit is the electronics standard...
Quick Reply: Airbag LIGHT just came ON
