996 Forum 1999-2005
dropping transmission
Old Dec 28, 2019 | 04:16 PM
Thibaulb24's Avatar
Thibaulb24
Default dropping transmission
I'm attempting to change the clutch but I can't seem to get the leverage or room to undo the top bolt in the transmission. What tools/ extensions have yall used to get to that bolt? I already have the engine and trans lowered as far as i can. I also have two electric impact wrenches but neither could break free any of the bolts, would an air impact have better luck?
Old Dec 28, 2019 | 04:28 PM
dporto's Avatar
dporto
I’ve only ever done it by dropping the transmission and engine completely as a unit. Once you do so, it’s very simple. When you say you’ve dropped the engine/transmission “as far as you can”, - do you mean all the way to the crossmember? I’m pretty sure that will get you 3” or so of space - plenty to get your extensions into that pesky top bolt. All I could suggest at this point is that perhaps a heavier extension (1/2” drive or even 3/4” drive) will serve you better as the lighter/thinner ones tend to twist - reducing the amount of torque you can apply to the bolt. Good luck👍
Old Dec 28, 2019 | 09:34 PM
yelcab's Avatar
yelcab
I just did one a month ago. I used a very long 20 inch long 3/8 extension, a 6 inch wobble extension, a 3/8 short socket, connected to a long 24 inch 1/2 ratchet, and snap that sucker loose. Then use a driver to quickly remove the bolt. An impact driver from that long of a distance is not very effective at delivering the torque.
Old Dec 28, 2019 | 11:22 PM
shft22's Avatar
shft22
That is more or less what I did. I also removed the air box before lowering the front of the engine down. I was able to lower it quite a bit, but I had very old engine mounts at the time, not sure if that made a difference.
Old Dec 28, 2019 | 11:48 PM
garrett376's Avatar
garrett376
I use 6 or so extensions, and reach the bolt from the front of the transmission where there's room for a big wrench to rotate. The numerous extensions permits it to bend slightly over the transmission to fit - no specific wobble fitting was ever needed when I've done this.
Old Dec 29, 2019 | 08:48 AM
808Bill's Avatar
808Bill
Lower the motor to the cross bar, that should give you plenty room.
Old Dec 29, 2019 | 12:58 PM
yelcab's Avatar
yelcab
No need to lower the engine. Just use long extensions,
