No spark at all, I think its about the immobilizer.
Sorry, I didn't reply earlier. But I've tested the cam sensor on bank 1 by cranking the engine and hooting a voltmeter and see if it getting anything (which I did get a little bit of voltage.) I'm going to check it again today, and do a temporary wire reroute to the dme so I can make sure that the signal is reaching is good. (My crank sensor code was caused by crummy wiring, so that might be the problem on the crank sensors.)
3. Keys
When I got the car, I only got one key and I'm pretty sure that it is working. I'm planning on pulling out the pill and test the key by itself just to see if it will do anything different, but I don't think that the key is at fault. Also, the lock button works fine.
If there was a problem with the key, the starter would not be engaged as noted by someone else above. I believe you would need the car at the dealer for them to program the key to the immobilizer (actually they code the immobilizer to the key), so this would be costly as well.
Daniel, my advice is to get the RFID inside the keyfob checked out or purchase another keyfob from Porsche and have them program it to the car. I know Porschetech3 is the expert here, but I like to rule out the obvious. I've read so many thread similar to yours and in the end it was simply a faulty keyfob not properly "hand-shaking" with the ECU which in turn, prevented the car from starting. It couldn't hurt. If you didn't want to tow your car to a dealership, then send the keyfob and immobilizer to ECU doctors. Good luck!
Well, problem solved. The cam sensor connector was in fact swapped with the crank. The previous owner seemed to have the engine out and it was an obvious problem which was overlooked when I did a continuity check and the crank connector and it passed.
Glad you got it fixed !!!
The following 4 users liked this post by 808Bill:
Originally Posted by Daniel Boone
I'm glad I took your advice and double checked it. Thank you very much for that!
I see you took my advice when I spoke with you on Facebook and asked the guys here!!
I told you they would sort it, actually had porschetech3 in my head for being the one to solve this one , good job ??
Porschetech3 (12-30-2019)
