Starting issues
Starting issues
My car has decided it doesn’t like starting. When I turn the all the electronics come on but the car doesn’t crank. After repeated attempts it will turn on. I don’t think it’s the starter because when it does turn on it cranks right up. Would this be the ignition switch?
Or Y cable (do a search...there should be plenty of threads)
You can bypass the clutch switch to confirm if it's that or something else before spending any money..
