Replacing engine mounts - raise to "final location"?
The workshop manual says to raise the engine to its "final location" before attempting to tighten the engine mount bolts, but I cannot find guidance on where this final location should be. Is there a clearance measurement reference point for the proper mounting height of the engine?
I jacked up the engine slowly until I felt the weight that it almost started to raise the car. I screw in the bolt by hand until tight. Release the jack and saw no drop or movement. I tighten up the the torque spec and done. The only thing is make sure the square part of the bolt matches and go into the square part of the carrier.
808Bill (10-21-2019)
I measured how much clearance there was on top of my engine (the manifold) and hoses essentially before replacing the motor mounts. I lifted the engine a few inches until there was almost no space left, and nothing was being pinched.
And that’s where I left it while replacing the mounts.
It was only after I tightened the mounts that I let it back down again. The engine assembly weighs maybe 400-500lbs, so when jacking it up, the car will raise up several inches because the weight of the engine is enough to cause the suspension to compress on its own.
I also put jack jack stands as a safety precaution if the jack failed. Use wooden blocks on the bottom of the engine case (oil sump plate).
Just a car guy
What I've stated may add more confusion. You might want to find the other thread by optionman1 where a link to the Pelican article is given. They may or may not agree with my suggestion, but if you can, it's always good to make gradual steps in tightening things.
