Door latch replacement
Im trying to gather all the parts I need to replace both door latch and inside/outside handle microswitches on my Carrera C4S 02'.
Both doors are giving me a hard time.
Right now the left door is going down when I pull the outside handle but go up as soon as I open the door.
I have to hold the inside handle, and release it as soon as I close the door to close it when Im inside the vehicule.
To get out I usually roll the window down and use my key to lock the car which raise the window back up.
Im now looking for parts and came across theses on ebay.
I was looking at the VW replacement units instead of the genuine Porsche and I know you have to swap the latch from the Porsche unit or atleast modify the ones on the VW units.
But the ones I found seems to have the correct latch...
What do you think? Would you give it a try?
https://www.ebay.ca/itm/Brand-New-Power-Door-Lock-Actuator-for-VW-Jetta-Golf-GTI-MK4-3D1837015A/312796288848
This is what both VW and Porsche door latchs looks like.
I also would like to confirm theses numbers for the inside/outside microswitches:
Inside handle microswitch: 996.613.123.00 (Same both sides)
Outside handle microswitch: 996.613.125.00 (Left) / 996.613.126.00 (Right)
Hugo
See a detailed write up here https://rennlist.com/forums/996-foru...-detailed.html
