996 Forum 1999-2005
Steering
Old Jul 29, 2019 | 12:59 PM
roccocaiazza's Avatar
roccocaiazza
Default Steering
I have a rattle in my front and Porsche mechanic found a loose steering linkage. Going to cost about $1000 to fix. Car has 108,000 miles, runs great and the rattle does not effect the ride. Is there anything else I should look for with a car with this mileage?
Old Jul 29, 2019 | 01:16 PM
hatchetf15's Avatar
hatchetf15
What could possibly cost $1000 unless replacing the whole steering rack?
Old Jul 29, 2019 | 02:22 PM
DBJoe996's Avatar
DBJoe996
Uhhhh....loose steering linkage? What is he talking about? Is the entire steering rack loose? Replacing inner and outer tie rods is a different story. At 108K miles, every rubber bushing in the front suspension should be checked. Your struts should be replaced and the brakes rebuilt with new rotors and pads. This is only the beginning....
Old Jul 29, 2019 | 02:24 PM
thurstonpowers3's Avatar
thurstonpowers3
Replacing both front inner and outer tie rods would run about $1000.
Old Jul 29, 2019 | 02:33 PM
roccocaiazza
Default Steering Rack
The cost is $1392 FOR A NEW STEERING RACK, OUTER TIE ROD ENDS and alignment
Old Jul 29, 2019 | 02:35 PM
DBJoe996's Avatar
DBJoe996
That sounds about right.
Old Jul 29, 2019 | 02:40 PM
roccocaiazza
Anything else on suspension I should examine?
Old Jul 29, 2019 | 04:30 PM
Rdrcr's Avatar
Rdrcr
Struts and Strut mounts.
Mike
Old Jul 29, 2019 | 05:32 PM
hatchetf15's Avatar
hatchetf15
control arms, motor mounts, transmission mount. If these have not been addressed before, they are well past their prime now.
Old Jul 31, 2019 | 01:20 PM
roccocaiazza
Default Steering rack
Everything I read suggests I should have a leak in the rack or steering problems if the rack is bad. I have none of these problems, just a rattle. Any ideas or am I wrong.
Old Jul 31, 2019 | 01:27 PM
808Bill's Avatar
808Bill
Does this include an alignment?
Make sure you get and accurate break down of what's being done.
Old Jul 31, 2019 | 01:44 PM
roccocaiazza
Yes it includes an alignment. Very good Porsche racing shop.
Old Jul 31, 2019 | 02:04 PM
dporto's Avatar
dporto
That would be a used/re-built/re-manufactured steering rack. New is $3 or $4k... Ask me how I know (the Dealer broke mine, wanted to charge me $3500 for a new one and then acted like they were doing me a favor by only charging me $1100 for a re-manufactured one... ... yup Dealers are one of my pet peeves).
Old Jul 31, 2019 | 02:56 PM
strathconaman's Avatar
strathconaman
Check out:
https://shop.rackdoctor.net/1997-200...5995-25493.htm
Old Jul 31, 2019 | 03:06 PM
hatchetf15's Avatar
hatchetf15
OP,
Could I get a clarification on what the tech says is “loose steering linkage”? No mention of leaks, so could be rack pivot joint or any part of one of the tie rods. Big cost delta between replacing an outside tie rod vs a rack redo.
