'03 - what does "hi-fi digital sound" mean?
So, I'm having the common problems w/ the CDR23 that are so well documented. I'm considering just replacing the head unit with something after-market.
I have read this is more difficult/impossible if the car has Bose speakers. My question is - is the Bose upgrade listed separately as an option? I have the original window sticker, and it lists "hi-fi digital sound", but the word "Bose" does not appear anywhere.
Thanks.
Thanks.
It means it uses the fiber optic cable. Yes, Bose is a separate option.
I have the "hi-fi digital sound" in my 03 also.
If you can't just replace the head unit without finding a special adapter.
Anybody know if there is a howto somewhere regarding an after-market HU I could install, that would possibly bypass the original amp? Something that wouldn't require hacking up the existing wiring?
Rocky Mountain High
Call Crutchfield and they can help you with the adapter, the installation kit, and a new head unit. The speakers are the weak link in the system. If you really want to improve the sound quality of your system, then you’ll need new speakers. I went with a Kenwood head unit and a Focal amp and speakers when I upgraded the system in my 996. That was quite a few years ago, and I’m sure there are many great new choices available now. My car had the Bose speaker system prior to the upgrade, and the Focal speakers were a significant improvement.
Thanks.
Do they have faulty information?
I've read elsewhere that the only way to bypass the factory amp would be to run new speaker wires. Is that correct?
I'm willing to use the factory amp, if it will work w/ a replacement HU. Is there any way to verify the amp is working?
I have the hi fi system on my 04 and kept the amp, change out the head unit and use the MOST converter box, you can find all the info you need in the link posted below. it all works great.
https://rennlist.com/forums/996-foru...ctory-amp.html
I'm trying to determine if the problem is the HU or the amp; is there an easy way to diagnose it? I have the red light on one of the orange connectors at the amp, for what that's worth...it is lit for about 1 second, goes off for maybe a quarter of a second, then repeats.
Rocky Mountain High
It would seem to me that this will be a fairly easy installation with a MOST-HUR adapter.
One thing to consider: the thing that makes most aftermarket installations look bad is the trim around the new head unit. Some of them are recessed into the dash, some of them have textures and colors that don’t match the 996 interior. I don’t have a recommendation for you in that regard, I’m just giving you my opinion.
Another thing to note, since you mentioned bluetooth, is that the bluetooth telephone option for most aftermarket systems is fairly useless in a 996, unless you’re siting still in the car. The combination of road noise and engine noise in the cabin of the 996 make it very difficult to have a telephone conversation using bluetooth.
I use these guy's stereo parts, did the kid C2 DIN install using their kits, and my C2 also. They specialize in Porsche kits.
https://cai-store.com/
I've learned quite a bit since I first started this thread. I am considering buying a new HU and simply bypassing the amp. So, I'd need to get speaker output from the new HU into the boot to connect to the speakers.
Has anybody done this? Is it difficult to get the wiring in place? Is this feasible, or am I missing something?
Thanks!
Thanks!
Thanks!
