Acceptable water temps for a 996 Cross Post
Cross Post from HPDE / Racing
What is the acceptable range of water temp for a street driven 996 on track days?
What is the point at which you should pit if it gets too high.
I have a dash mounted OBD II Scan gauge.
I can monitor water temp and MAP Air temp, but not oil temp.
I am starting to experiment with higher rpm (lower gear) driving and seeing water temps up 7-8 degrees hotter.
Ambient temp ranges 70 - 83 degrees.
Any input would help. Some summer track days ahead, I don't want any surprises.
David
David
I've seen water temps go as high as 210 on my car in 80+ degree weather at the end of a 25-30 minute run. ideally, I'd prefer if they were below 200. This was with a new water pump and all 3 CFS radiators. I monitored oil temp and it would regularly get to 230-240 after about 10-15 minutes. I had a 2 qt mantis pan with a oil cooler that ran up front, so that helped.
I'd say 210 is probably safe....ish....
