996 Forum 1999-2005
Muffler Bracket
Old Jun 11, 2019 | 08:53 PM
Astro's Avatar
Astro
Default Muffler Bracket
Does anyone know of an inexpensive way to get the muffler attachment bracket, #13 shown below ?
When we removed my mufflers, we had some trouble and these got destroyed.
Old Jun 11, 2019 | 09:00 PM
wildbilly32's Avatar
wildbilly32
Dang! Auto Atlanta $559 per side!
Old Jun 11, 2019 | 09:04 PM
dan_189's Avatar
dan_189
I'm sure there are quite a few second hand?
When I replaced my mufflers I came across the price when looking for the torque specs... Not cheap for a bracket
The factory manual doesn't have a torque spec for the through bolts
Old Jun 11, 2019 | 09:09 PM
wildbilly32
Dan has a good idea. Check with the Porsche part out businesses. A lot of the cars are front end damage which should leave these brackets in good shape.
Old Jun 11, 2019 | 09:14 PM
SoCal911t's Avatar
SoCal911t
If the used ones on Ebay aren't inexpensive enough, my only suggestion is to try to steal them off of someone else's car.
Wow, I guess I won't be doing any business with Auto Atlanta. They're $279 at Sonnen (which is still crazy expensive).
Old Jun 11, 2019 | 09:21 PM
Astro's Avatar
Astro
Found some on EBay, great suggestion. The next question will be if they can be welded back onto the old mufflers or if that's a lost cause.
Old Jun 11, 2019 | 09:27 PM
wildbilly32
You are right. Just added them to my bookmarks just in case for the future.
Old Jun 11, 2019 | 09:28 PM
dan_189's Avatar
dan_189
Welding?? Che?
I'm confused, the brackets bolt to the mufflers then the bracket bolts to the carrier which is bolted to the engine - nothing should be welded into place...
Old Jun 11, 2019 | 09:38 PM
Astro's Avatar
Astro
Originally Posted by dan_189
Welding?? Che?
Well, in the process of removing the mufflers, we ran into some difficulty and ended up cutting thru the brackets(so they are unusable) and would need to be welded back to the mufflers themselves before bolting them back into place.
Old Jun 11, 2019 | 09:42 PM
dan_189's Avatar
dan_189
Ah okay I see - I thought that might be the case. So basically the mufflers and the bracket were damaged in the process... Time for some performance mufflers + new (second hand) brackets!
Old Jun 11, 2019 | 10:12 PM
cds72911's Avatar
cds72911
I have a set of 996.1 and 996.2 in the attic of the garage (yes, they are different). Message me which ones you need and a reasonable offer, and they're yours.
Old Jun 11, 2019 | 10:33 PM
wildbilly32
Perfect! Now that's one thing that makes a great forum. Kudos!
Old Jun 11, 2019 | 10:41 PM
cds72911's Avatar
cds72911
There are brackets integral to the muffler, that bolt to the part you show (#13) with two vertical bolts and nuts, which in turn bolts (3 horizontal studs tack welded into #13, fastened with nuts) into a bracket that is bolted to the engine. If you cut the bracket on the muffler, #13 alone won't solve your issues, you need to repair the integral bracket or replace the muffler.
Old Jun 11, 2019 | 10:48 PM
Astro's Avatar
Astro
Understood, we did a poor job on this and now are trying to figure out the best and most cost effective solution.
Old Jun 11, 2019 | 11:09 PM
su8pack1's Avatar
su8pack1
It sounds like this long bolt through part 13 may have been your problem. The long bolt on both mufflers was rusted fast. I hack sawed mine off then got a metal pipe and new bolt that fit snugly through it. I then cut the pipe to size fitting it through the mesh. All turned out ok for me. Only about $5 in parts from the hardware store.
