Sliding the bottom part of the regulator out tightens the window to seal pressure. Sliding the bottom part of the regulator in reduces the window to seal pressure. If all seems right with the old regulator position, mark where they are now and use that as a starting point for the new regulator.
I'm not sure exactly what your question is.....Are you trying to figure out how to slide this part off? Under the door, there is a rubber plug that covers the bolt that you need to loosen. Once you loosen that, the unit will slide out as normal.
I forgot the mark and cleaned out.
After I installed the new regulator it seems a bit tight when the windows went up and down.
nope, Jaycote!
To adjust window's seal pressure properly.
