more than one type of IMS replacement?
I'll hopefully be buying a 996 very soon, and I'll want to replace the IMS bearing.
Is there more than one vendor/solution? Difference in cost and/or effectiveness?
Thanks.
Thanks.
Google it...The IMSB topic has been beaten to death over the years!
There is only one "solution" and that's The IMS Solution manufactured by LN Engineering. Check out theimssolution.com This puts the Carreras on par with the Mezger engines. The bearing will last the lifetime of the engine and I've heard of people moving the IMS Solution bearing over to a newer engine.
The IMS Solution is not cheap, but worth every penny. It really boils down to your budget. LN Engineering has less expensive options, but the bearings will have a service interval.
"This puts the Carreras on par with the Mezger engines."
Nutty indeed!
^^^ Uh... Not really...it only put the IMSB on a par with the Mezger...the IMS(B) is only one of the many differences that make the Mezger engine (as in the GT3) far superior to the NA M96. One other major difference being the Nikasil coated cylinder bores. There are many others as well, that both create far more power and increase reliability/longevity of the Mezger design used in the GT3 and the Turbo's (as well as GT2). This is not to say "The Solution" is not a great upgrade for the M96 platform - it is...Just that it doesn't make a M96 on a par with a Mezger (except for the IMSB)
Nutty indeed!
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
It is good that you like the IMS Solution by LN, but please, don't give misinformation to people
So, after dong some reading, it seems like these are the options (please let me know if there are others):
Just looking for confirmation that I understand the situation.
I assume most people here, when they address their IMS, get the LNE Retrofit?
- Pelican Parts makes a replacement that doesn't seem to improve on the flawed design
- LN Engineering makes the "Retrofit", which uses ceramic bearings and is much better than the original, but is still a sealed bearing
- LN Engineering makes the "Solution", which uses roller bearing which are oiled w/ engine oil
"There are more than one solution out there. DOF from TuneRS is another one, without going outside of US"
Actually there is only one "IMS Solution"... and it's patented (it's also a plain bearing - as used in the early air cooled cars as well as the Mezger designed water cooled turbos etc.). The DOF from Tune RS is just an oil feed for the existing ball or roller bearing. I won't go into all the intracies of this but suffice it to say there are many (both good and bad)...
Received 1,166 Likes
Actually there is only one "IMS Solution"... and it's patented (it's also a plain bearing - as used in the early air cooled cars as well as the Mezger designed water cooled turbos etc.). The DOF from Tune RS is just an oil feed for the existing ball or roller bearing. I won't go into all the intracies of this but suffice it to say there are many (both good and bad)...![thumbup](https://rennlist.com/forums/graemlins/thumbup.gif)
Different technical approaches, for the same "problem" but both claim to be a definitive solution. We can discuss which technical approach each like more (I kind of prefer keeping the Porsche design bearing), but further than that I don't see why I we should give more credit to one solution than other (so far, the results are quite similar)
Nutty indeed!
Nutty indeed!
Great! I always wanted to be royalty. My first appointment is to name you my personal protologist. Scratch n' sniff Doc Parris!
As in my post to Dporto, I meant the darn plain bearing in relation to the Mezgers! And no, Neither TunerRS DOF or the "EPS solution" are real solutions in my book. Just copy cats.
But if you want them, more power to you. Can you say, "BOOOM SHAKA LACCA BOOOM!!!"???
