New to me 996 with coolant intermix issue
#31
Spring steel wire wound and magnetic.
Definitely magnetic, not aluminum. Wire wound steel, something that would have been a part of an oil seal. I suspect that when the rear main seal was pried out that the spring remained in the case and was mangled by the rotating crank shaft!
#32
Wow! Hard to believe that whoever removed that seal didn't realize that there was supposed to be a spring in it (they obviously came away with only a piece of plastic/rubber on their pick). Maybe the spring fell into the case/onto the shaft, prior to removing the seal? That would most likely cause the seal to leak... Maybe the seal was pushed in to far upon initial install? Lots of questions, and I suspect many more to come. Good luck with the tear-down and subsequent build
#33
Today went well. I was able to borrow the cam holding tools from a fellow PCA club member and rennlist poster and was able to remove the camshafts, lifter towers and cylinder heads. I found what I think is the source of my intermix problem.
Hard to believe that a small crack can cause such a big headache!
#34
Just a car guy
Today went well. I was able to borrow the cam holding tools from a fellow PCA club member and rennlist poster and was able to remove the camshafts, lifter towers and cylinder heads. I found what I think is the source of my intermix problem. Hard to believe that such a small crack can cause such a big headache!
I had to say, something. Marked...
Please add photos and more details, if you can. We love threads like this.
#35
It's hard for me to believe that such a small crack can cause such a big headache!
This picture is from the number three cylinder.The crack can be felt when dragging my finger nail across it. Based on other posts I was expecting to find it on cylinder number six.
#37
Thats the easy one to fix as per Len Hoffman($450) that goes from spark plug hole to welch plug. The hard one ($750) goes from spark plug hole to exhaust valve guide..
#39
Len is very explicit on the https://newsite.hamheads.com website as to how to pack and ship the heads.
#44
Busy day today,
cases split and crank housing and IMS shaft removed. Tomorrow I’ll take a look at he the main and rod bearings.
bbboomer67 (06-26-2019)
#45
Ingenious use of the maxjax!
