What is the best street performer tire
#31
#32
Received 2,122 Likes
Goodyear Eagle GT's!
#36
#40
The other reason to go with all season is the tread life will be better than pure summer tires. But - I’m not driving my car on a track - so ultimate performance was not critical to me. As a point of reference our VW GTI came with the same tires from the factory; they now have 35,000 miles and still have a ton of tread left. That car gets driven every day rain, shine or snow and it was fine.
Daryll
#41
The biggest surprize for me was wet weather traction,
^^^ this is at a WGI HPDE in the rain, my first time driving at high speeds on a wet surface. They worked pretty good, not as good as a set of $1700 tires I would think, but good for the money.
On a dry track, their grip matches my ability, PCA HPDA yellow run group.
As I learn to get more out of the car on every type of corner, they gently let me know where their limit is as the car rotates.
If you use a tire with a lot of grip on a track, the "OH, S##T", moment does not give you very much warning. Something you should be aware of if you are tracking and learning with your 996.
12,000 miles on the front, the 295 rears, I replaced at 8000 miles.
My alignment is just about spec and tire wear is very even.
They get flat spots after a week if not driving, they smooth out after 10 or so miles.
#42
Why does Tire Rack put the PS2 and PS4S in the same category? I’m sort of miffed. I️ bought Regular PS’s two years ago in the OE 18” size for my C2 and neither tire was made in that size then. Now they are both cheaper than what the PS’s were.
#44
I'm STILL running Hankook Ventus V12 Evo2's - this is my 3rd set. I have found no reason to not continue buying them. They do get a little greasy when really hot, but otherwise they're awesome affordable UHP summer tires.
If you read reviews, make sure you are reading the Evo2 reviews. The original Ventus V12 Evo suffered from sidewall stiffness issues that were corrected with the Evo2.
