Headlight and Directional Bulb Mystery
My headlight went out recently, and I replaced it with an H7 bulb. The bulb below it is also an H7, so I replaced that one too. As soon as I drove the car, the directional was blinking really fast and I noticed my turn signal was no longer working. I replaced the turn signal bulb and that didn't solve the issue. Upon further investigation, I noticed that the headlamp enclosure has H7 marked near both Hi/Lo beam headlight sockets. But on the bottom socket, there's a black stamp that looks to show "H5" or "H6"...I can't quite make it out. These are completely different bulbs, from what I understand. I'm wondering if I shorted it out by using an H7. Has anyone run into this type of issue before? I've never tested electronic equipment before with a voltage meter, so I'm unfamiliar with that process. Any suggestions?
Thanks guys!
Thanks guys!
Received 1,093 Likes
High Beam H7, 55W
Low Beam H7, 55W
Fog Lights H7, 55W
Parking Light W 5 W
Turn Signal Light P 21 W
From the owners manual
Pop out the headlights again and reseat them
Check all fuses in row A
Check fuse B6
Check fuse D7
Low Beam H7, 55W
Fog Lights H7, 55W
Parking Light W 5 W
Check fuse B6
Check fuse D7
DB Joe, thank you! Fixed it...Turned out to be a fuse and I couuldn't locate it.
