996 Forum 1999-2005
Broken headlight base
Old 03-26-2019 | 07:34 PM
DGI's Avatar
DGI
Default Broken headlight base
Looks like my drivers side headlight base is broken. The tab that retains the plug snapped. I can plug in headlight then slide it into place but not sure how this will hold up long term.
Is there a write up on replacing the headlight base? Is it even worth it?
Old 03-26-2019 | 07:40 PM
De Jeeper's Avatar
De Jeeper
Ebay is your friend. Lots of boxter parts on there and its the same. Just put the part # in google. Its stamped on there somewhere.
Old 03-26-2019 | 07:41 PM
DGI's Avatar
DGI
is it just the 4 height adjustment bolts i need to remove?
rearward bolts are corroded on both sides. Might as well source replacements lol
Old 03-26-2019 | 07:44 PM
DGI's Avatar
DGI
https://www.pelicanparts.com/More_In...631-041-00-OEM
looks like the height adjustment bolts are not the mounting hardware
Old 03-26-2019 | 07:53 PM
rileyracing1's Avatar
rileyracing1
Yep happened to me awhile back on one of my Cayennes ... No big deal .... I was going to get one on ebay and was surprised to find out thru Porsche that that light bracket tray was something like a $100 new so i picked it up new and it took me about an hour to do ... Takes more time positioning the grommets on and under the tray than actually installing.
Old 03-27-2019 | 01:30 AM
lowpue's Avatar
lowpue
Here you go....$35 shipped...covers shipping and if I am lucky a little left over for starbucks…
996.631.041.00
Old 03-27-2019 | 07:25 AM
DGI's Avatar
DGI
996.631.041.00
pm incoming sir!
Old 03-27-2019 | 10:59 AM
JjyKs's Avatar
JjyKs
Thread with some images on how to remove the part without readjusting the headlights
https://rennlist.com/forums/996-foru...g-bracket.html
Old 03-27-2019 | 12:16 PM
Splitting Atoms's Avatar
Splitting Atoms
Lowpew's base doesn't have the yellow clip, but it looks like the clip from your broken tray is attached to your plug. You will need to remove it from the plug and transfer it to the the new tray. The yellow clip slides up and latches the plug to the base.
I had one tray that was missing the yellow clip. I bought a used tray off eBay fairly inexpensively. When I replaced the old tray, I just unscrewed the large thin nuts off the stands and swapped the trays out. It didn't take long to do.
Old 03-27-2019 | 02:24 PM
DGI's Avatar
DGI
Thanks for the tips sir!
Your car is looking awesome by the way
Quick Reply: Broken headlight base
