996 Forum 1999-2005
Engine failure
Old 03-19-2019, 07:00 PM
robo_porsche
robo_porsche's Avatar
Default Engine failure
My 996 c2 2002 engine became junk last autumn during a track day. One of the connecting rods stuck to the crankshaft and totally ruined the engine. I have found a new engine but why do you believe my old engine had this failure?
My old engine seemed to work just fine before the crash and was well maintained.
Robert
Old 03-19-2019, 07:03 PM
808Bill
808Bill's Avatar
Sorry to hear that.
Rod failure has been an issue on these. A google search will give you some more data.
Old 03-19-2019, 07:27 PM
AnthonyGS
AnthonyGS's Avatar
Track use is hard on engines. At this hp / liter level lots of things are a compromise. If I had to guess I’d suspect oiling issues during track conditions to be a contributing factor.
Old 03-19-2019, 08:28 PM
Mike Murphy
Mike Murphy's Avatar
Received 1,580 Likes on 987 Posts
^^ what he said
Old 03-19-2019, 08:39 PM
sb3
sb3's Avatar
Oiling problem most likely. If you decide to track your car with the new motor get a deep sump and possibly an Accusump too.
Old 03-19-2019, 09:56 PM
Prelude Guy
Prelude Guy's Avatar
It's just a poor engine design. One of the design flaws was the oiling system. It doesnt like when the car takes hard prolonged turns.
Old 03-19-2019, 11:29 PM
lowpue
lowpue's Avatar
My engine blew in long right hand high G turn because of oil starvation...common failure it seems. New 997 engine was put in with deep sump.
Old 03-19-2019, 11:38 PM
yelcab
yelcab's Avatar
That is a known weakness of a wet sump design. You want a dry sump engine, like an old aircooled version.
Old 03-20-2019, 01:47 AM
Chris(MA)
Chris(MA)'s Avatar
996 is not a weapon for the track IMHO
Old 03-20-2019, 01:57 AM
Bash Hat
Bash Hat's Avatar
Agreed. Track is a whole other environment that pushes a street car beyond its intended limits.
Old 03-20-2019, 07:53 AM
robo_porsche
My mechanic didn’t think it had anything to do with oil starvation (he is racing himself in a boxster). He thought it had something to do with overheating issues or a bearing that got damaged with debris of some kind. He said that if you race and then suddenly switch of the engine the heat can increase and make the bearings stuck. I usually cool down before I stop after a track session, but maybe not enough.
I already have a deep oil pan with x51 baffles. Unfortunately I can not really afford a turbo or a gt3, but sure they are better prepared for the track.
Any other thoughts ?
Robert
Old 03-20-2019, 10:37 AM
Imo000
Captain Obvious
Super User
Imo000's Avatar
The engine has to be red hot for those bearings to stick. You would have plastic pieces on top of the engine melted to the block if that was the case. Lack of lubrication is probably what did you in. Boxters have a better engine placement so high G corners have less effect of the engine lubrication.
Old 03-20-2019, 12:11 PM
Batteaux
Batteaux's Avatar
I had exactly the same failure with my 2001 3.4 which was equipped with a baffled sump and an extra scavenge pump as protection against starvation. Following the engine failure at Mosport, It was sent to Jake Raby for a rebuild and after assessing the failure he attributed it not to oil starvation but to breakdown of the oil, under the high stress of track use, leading to loss of viscosity and oil pressure, immediate wear of the con rod bearing and eventual failure of the bearing and the con rod. He actually sent me a graphic detailing the stages, under track use, that lead to failure due to breakdown of the oil leading to loss of viscosity and pressure . He calls it "the snowball effect". I had been sharing the car with my son that day so it was running in two run groups and the oil presumably had the chance to get real hot. So for mine, the identified cause was not starvation but oil breakdown (Motul at the time). The propensity for such failures is why Jake specs Joe Gibbs XP9 oil for track use in his engines.
Old 03-20-2019, 01:40 PM
Ratchet1025
Ratchet1025's Avatar
Thank you for sharing, this really confirms my process to change the oil after every 2 track days. Fingers crossed!
Old 03-20-2019, 02:13 PM
Cuda911
Cuda911's Avatar
I disagree. Tons of 996's have tons of track hours with no motor failure.
Quick Reply: Engine failure
